Old 09-02-2020, 11:32 AM   #1
doughpat's Avatar
2019 22' Sport
Bend , Oregon
Repair process for dented rear exterior
Hi all - managed to back into a stationary object the other day. Dang.
Used a pneumatic dent puller and got some of the dent out.
At this point I believe the rub-rail (or whatever its called) may be preventing the skin from popping out any further.
My plan is to remove the rub-rail (perhaps I can salvage it, but more likely will need to be replaced), then spend some time pulling the skin dents out with the pneumatic puller. The skin is not accessible from the inside (its behind the shower wall).
Replacement of the exterior skin is not in the budget. I'm sure it won't be perfect, but I'm also confident it can be "pretty good".
Not quite sure how to proceed on removing the rub-rail, or where to get a new one.
Any advice appreciated.
ID:	377493   Click image for larger version
ID:	377495   Click image for larger version
doughpat is offline   Reply With Quote
Old 09-02-2020, 04:29 PM   #2
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Ouch!
Shari
RMVAC | ACI - CO (CAC) Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 12-18-2021, 11:02 AM   #3
2019 16' Sport
Lakewood Ranch , Florida
Hi doughpat,
I just did the same thing. Can you give me any repair tips?
Gary
gbethune is offline   Reply With Quote
A Pro's Repair on Dented Aluminum Haoleman Belly Pans & Banana Wraps 6 09-26-2012 06:15 PM
dented roof panel, with popped seam, Hard Fix?? dkutz Roof 3 02-13-2006 11:27 AM
Dented skin repair from awning rip-off givememoreli Ribs, Skins & Rivets 3 07-18-2005 06:28 PM
help on dented area pinkflamingoes Ribs, Skins & Rivets 40 05-28-2004 06:14 PM
Dented panel replaced Jim W Ribs, Skins & Rivets 1 07-08-2002 07:07 PM
