Old 07-13-2019, 09:40 AM   #1
1970 25' Tradewind
anderson , South carolina
Rear Panel Replacement Options
My daughter backed my 1970 25 ft. Into a board and bent lower rear corner panel. Anyone know is other
Years or models use this same panel. This is the right side. Thanks for reply. BOB COOKE
Bob Cooke is offline   Reply With Quote
Old 07-13-2019, 11:12 AM   #2
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
69-82 models are the same, check out Out of Doors Mart on the internet. They have a variety of panels.
cole3444 is offline   Reply With Quote
Old 07-13-2019, 12:24 PM   #3
batman's Avatar
1964 22' Safari
modesto , California
If it's just dented perhaps it can be popped out?
A photo would be handy to see the extent of the damage.
If you find a used panel, the rivet hole pattern may not be drilled exactly the same as the original.
If you do need the original 2024-Alclad aluminum sheet goods. Aircraft Spruce has that and Cleco fastener's and tool, etc. They will ship it to you.
https://www.aircraftspruce.com/catal...sheet_2024.php
Best of luck
-Dennis
batman is offline   Reply With Quote
AC replacement-options, options... Belegedhel Furnaces, Heaters, Fireplaces & Air Conditioning 5 09-12-2018 08:56 AM
Argosy Airstream Motorhome 1974 24' Rear bunk bed all options All new tires eBay Watch Airstreams on eBay 0 10-13-2013 03:40 PM
Converter connundrum: fuse panel options? Phrunes Batteries, Univolts, Converters & Inverters 0 08-17-2011 07:53 PM
Painting Rear bath options SilverHoot General Interior Topics 11 04-07-2011 08:31 AM
rear bumper storage options projector General Motorhome Topics 5 03-27-2010 07:11 PM
