Old 06-15-2022, 07:41 PM   #1
Lhenry83's Avatar
2019 27' Globetrotter
Fredericksburg , Texas
Paintless Dent Repair (PDR)
AF Experts,
I have a 2019 Globetrotter with a small “quarter-size” dimple just behind the rock guard, below the “Globetrotter” label. I’m think I would like to have someone try Paintless Dent Repair versus the dealer repair the WHOLE PANEL. Has anyone tried PDR? If so, can you recommend a kit via Amazon, etc.?
Lhenry83 is offline   Reply With Quote
Old 06-15-2022, 07:51 PM   #2
jeffmc306's Avatar
McHenry , Illinois
There are several threads on PDR, some do-it-yourself with kits from Amazon.
One post by GettinAway found a shop that did a great job removing a dent from the end cap of their Globetrotter. Scroll down to #7643 and a few after for the name of the shop.
Good luck!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 06-16-2022, 06:00 AM   #3
Lhenry83's Avatar
Good luck!
Thanks Jeffmc.
I’m interested in the DIY option and the Amazon link to what tool kit they used.
Old 06-16-2022, 08:16 AM   #4
jeffmc306's Avatar
McHenry , Illinois
Understood…
Here’s one example from Amazon that was mentioned in another post:
Here’s the other AirForums thread if you’re interested. I found it using the Search box on the Forum.
2018 FC23FB
WBCCI# 10258
RETIRED!
Old 06-16-2022, 08:18 AM   #5
2000 25' Safari
Denver , North Carolina
I had some serious damage and sent pictures to all the local PDR vendors. After looking they all said that their process would not work. They based this on experience with Pontoon boat pontoons, refrigerators, freezers, etc. I am sure some of the reluctance was that there are creases in the aluminum. My suggestion is to send pictures with your inquiry to PDR vendors. If it’s just a dimple, I have a few hail damaged places, forget about it….there will be more.
mbubbaca is offline   Reply With Quote
Old 06-16-2022, 08:27 AM   #6
Lhenry83's Avatar
Thank you for your help. Found the item on Amazon as a backup if my Airstream repair shop is NOT comfortable with the PDR process.
Old 06-16-2022, 08:05 PM   #7
Toaster Life
2010 23' International
Tucson , Arizona
We used to own a body shop. When we needed PDR for some jobs we contracted it out - the good PDR folks are true artists, if possible give them the job, it is not as easy as it looks. Experience with the tools can make the difference between an OK job and "where were the dents exactly? I can't see them". They have more experience with steel than Al, but experience does count.
Toasterlife is offline   Reply With Quote
PDR hot glue dent removal works s1000pre General Repair Forum 24 06-17-2022 06:06 AM
Paintless Dent Removal (PDR) to remove a dent? JakoVdL Clearcoat, Exterior Paint & Trim 2 10-19-2021 12:27 PM
35- Piece Gliston DIY Paintless Dent Repair Kit Bigventure Ribs, Skins & Rivets 7 12-31-2020 04:45 PM
Paintless dent removal Davadar Ribs, Skins & Rivets 46 08-23-2018 05:13 PM
