Old 09-18-2020, 08:58 AM   #1
Perpetually Perplexed
Krek's Avatar
Mobile Rail Bunkhouse
Farmington , MO
One Piece Door Skin Replacement?
The main door on the bunkhouse originally had four pieces of skin and a jalousie window.
Weíre eliminating the window.
Is there any reason that I canít reskin the frame with a single piece of aluminum on the exterior and interior?
Krek is offline   Reply With Quote
Old 09-18-2020, 09:21 AM   #2
1966 22' Safari
Fredericksburg , Texas
I see no reason why you canít. It would be nice to have a screen door like they had in the 60s. I think if I were to do as you are wanting to do, I would segment the interior skin and place a rectangular piece at the interior lockset. I would use rivnuts and pan head #6 screws so I could access the lockset mechanism some day if it breaks without having to drill out a bunch of rivets. We re-skinned the 55 door within a door and it was pretty simple. We did have to put a slight bend around the skin for a tight fit. Also, donít know if any support would be needed where the jalousie was.
Bubba L is online now   Reply With Quote
Old 09-18-2020, 09:33 AM   #3
batman's Avatar
1964 22' Safari
modesto , California
If you do not want a window in the door there is no reason not to re-skin the inside and outside of your door. It would be a good idea to clean up and rebuild the hinges, handels, locks, nobs and latches as well. You will have a brand new door.
After all that work, don't forget to make yourself a "door wedge"
https://www.airforums.com/forums/f48...ge-200171.html
-Dennis
batman is offline   Reply With Quote
Old 09-18-2020, 10:14 AM   #4
Krek's Avatar
Farmington , MO
That's some quality advice right there, thanks!
Old 09-18-2020, 10:18 AM   #5
Krek's Avatar
Farmington , MO
I can't find a replacement window for the door and our current camper has a solid door so we're pretty confident that we won't miss it.
I've already sourced replacement stainless steel hinges and I'm looking at options for the lockset.
The inside of the door frame has some aluminum bracing which I want to fortify and had several dozen loose 1.5 x 1.5 inch pieces of pine... not sure what their purpose was?
Can we replace floor piece by piece? tdturn2 Repairing/Replacing Floor &/or Frame 9 07-14-2022 02:10 PM
A-Frame to Skin Trim Piece FreeRenegade Exterior Restoration Forum 12 05-16-2021 09:09 PM
Any chance to find a piece of Bambi skin ? Aktundra Ribs, Skins & Rivets 1 07-01-2018 03:00 PM
Need a piece of Aluminum Skin Navigator Ribs, Skins & Rivets 3 01-08-2004 10:50 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
