Old 07-20-2020, 07:12 PM   #1
Linwood , New Jersey
Missing rivets in front
I see 3 missing rivets in the front as shown. When I look in the hole I expectto see a void but instead I see metal just inside the hole. What is this I am seeing and do I need to do anything with this?Click image for larger version
ID:	373458Click image for larger version
ID:	373459Click image for larger version
Fmazza is offline   Reply With Quote
Old 07-20-2020, 07:23 PM   #2
dznf0g's Avatar
Oswego , Illinois
The heads popped off. What you see is the shank remaining. Just take an awl and push them in. They'll drop inside the wall. Then install Olympic rivets in their place.
-Rich-
Old 07-20-2020, 09:19 PM   #3
I have the Olympic rivets with the washers.
Are the washers preferably or better without?
Old 07-20-2020, 09:43 PM   #4
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Olympic rivets
Fmazza, Better to use Olympic rivets without the rubber washers (if that is what you have). The Olympic rivets should just be buttered with sealant before being installed in the existing holes. Try to dry fit (test) a rivet to see if the existing hole is the right size for the rivets you have. Then push some sealant in the hole and when the buttered rivet is installed and popped it will be very well sealed. Hold the rivet gun firmly to make sure it doesn't jump off the rivet and mar your panel! You may find it a good idea to surround the area around where you are setting a new rivet with a piece of material so the rivet gun has something to land on instead of your aluminum panel. A few layers of cardboard is a cheap way to protect your skins. Just use painters tape to hold them temporarily in place. After you are done installing the new rivets clean off any excess sealant with a clean terrycloth towel. Use a Dremel type tool to smooth the top of the rivet. Hope this helps, Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 07-21-2020, 06:36 AM   #5
Any sealant recommendations? I have Capt. Tolley’s but I doubt this is what you have in mind.
Old 07-21-2020, 07:51 AM   #6
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
sealants
Fmazza, I would use either Vulkem or Acryl-R both are used by the factory and dealers to re-seal panels and rivets. The Capt. Tolleys Creeping Crack Cure is really great to use to seal very small seam leaks or around rivets to keep moisture from penetrating inside skins. But After use you should still use one of the caulks above to seal any seam or rivet for long term protection. DO NOT use any silicone based sealant on aluminum! Ed
Old 07-21-2020, 08:02 AM   #7
I have been having a hard time finding the acrylic-r applicator. Any idea where I can find?
Old 07-21-2020, 10:42 AM   #8
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
The underlying problem could be your tire PSI is too high causing a rougher ride, causing the rivets to pop out. Something to think about.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 07-21-2020, 12:21 PM   #9
2019 25' Flying Cloud
Lakewood , New Mexico
I was on a factory tour and had a chance to practice installing/shaving Olympic rivets. I asked the question about using or not using the washer. The way tech explained it plus installing a rivet with and without a washer and witnessing a much better seal with one, I would recommend using the washer.
BigTexRex is offline   Reply With Quote
Old 07-21-2020, 12:35 PM   #10
dznf0g's Avatar
Oswego , Illinois
I don't recommend. I used one with the washer...once. within a year the o-ring UV rotted and it came out, leaving a unseated/loose rivet.
-Rich-
Old 07-21-2020, 12:48 PM   #11
heslinhotel's Avatar
1989 29' Excella
1999 25' Safari
Youngsville , North Carolina
Fmazza, Acryl-R applicator was available from Outofdoors Mart. Around $30 as I recall.
heslinhotel is offline   Reply With Quote
Old 07-21-2020, 06:17 PM   #12
Thanks. I ended up ordering Vulkem 116 so it can arrive before our first trip. I will order Acrylic-R but this may be very similar to Vulkem.
Thank you.
Rivets, Rivets, Rivets PSU1981 General Repair Forum 3 07-17-2018 01:02 PM
Missing title, missing VIN in Texas. kristinatx Title, VIN & Registration 33 02-22-2016 09:54 AM
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 01:53 PM
Rivets Missing BIGED52 Forum Admin, News and Member Account Info 2 08-19-2006 10:01 PM
Missing Exterior Rivets carls017 Ribs, Skins & Rivets 5 10-13-2003 09:55 AM
