Old 10-02-2019, 08:44 PM   #1
1974 27' Overlander
Naramata , British Columbia
Missing rib?
Hello, Airstreamers! I'm new to the forum and new to Airstreams. We've got ourselves a '74 Overlander in the initial stages of restoration. When the interior skins and the insulation came out, we see what seems to be a section of missing rib just to the left of the door (see pics). There is no obvious sign of repaired damage in that area. Is it at all possible that it is meant to be like this? Hopefully, you will be kind if this is a ridiculously stupid question from a newbie! If it does indeed need to be replaced, please do point us in the right direction. Many thanks.
ID:	353449   Click image for larger version
Lonnajp is offline   Reply With Quote
Old 10-03-2019, 06:39 AM   #2
San Diego , California
That's just how they were made. The window prevents the rib from continuing all the way down to the frame so the cut them short. In 1969 (ours) they seem to have cut one full rib in half and used each piece in two different locations. The cuts are right where the A/C mounts making the A/C support a challenge!
Matt0k0 is offline   Reply With Quote
Old 10-03-2019, 09:40 AM   #3
1974 27' Overlander
Oh good - one less repair to make! Thanks for weighing in.
Old 10-03-2019, 10:58 AM   #4
Halford1's Avatar
2019 19' Flying Cloud
Canyon Country , California
Might want to check with Airstream "Eve" for the missing rib.
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
Halford1 is offline   Reply With Quote
Missing title, missing VIN in Texas. kristinatx Title, VIN & Registration 33 02-22-2016 09:54 AM
63 Safari Roof rib replacement airstream4 Ribs, Skins & Rivets 9 04-14-2008 11:04 AM
I Bow Before You (with plate in hand) Her-Highness Shari aka "Rib Queen" MileHigh Off Topic Forum 1 10-16-2004 01:47 PM
The first day. Broken Rib? Charming Wino 1974 - 1977 Overlander 12 03-07-2004 07:11 PM
bent/cracked rib? Jabba Ribs, Skins & Rivets 1 10-27-2002 07:04 AM
