Old 06-14-2024, 05:01 PM   #1
2023 27' International
Waynesville , Missouri
Loose(?) Rivet Replacement
We just got back from a 3 week trip. At the first stop for the night I identified 7 inside rivets that had popped their heads (thanks Iowa interstate roads). I also identified several where the head had pulled out enough to stick my finger nail between the head and the interior surface. Iím not sure if these loose ones should be drilled out and replaced, or just leave them until they pop out too. Iím inclined to replace them, but I could just be wasting my time. Is there a correct answer out there? Thank you in advance for reading thru this.
DAVSCH is offline   Reply With Quote
Old 06-14-2024, 05:35 PM   #2
2019 27' Globetrotter
Missouri Valley , Iowa
If it was mine - I would replace broken and loose rivets as soon as you could. The loose ones may "wallow" out the existing holes. That may make replacements less likely to hold and fit the original hole. And it's not difficult to replace interior rivets with just a drill and a rivet tool.
Dan
Farmer Dan is offline   Reply With Quote
Old 06-15-2024, 02:49 AM   #3
Thatís what I thought too
Dan-Thank you for the rapid reply. Replacing the loose ones now was what I thought too. Wallowing out IS the reason to do it immediately. It was the old Sergeant in me that thought everything should look uniform and like new. I hadnít really thought of the mechanics of what was going to happen if they were left loose. Looks like I have my first project of the day. 😀
Dometic Cook Top: LOOSE PARTS 2019 27FBQ International Loose Hardware Ray Eklund Stoves, Ovens & Microwaves 1 12-17-2023 12:07 PM
Exterior Trim, Did a Rivet or Screw come loose? OSCS General Repair Forum 3 09-17-2017 08:07 AM
What to rivet, and where to rivet it? DanielB Ribs, Skins & Rivets 5 04-27-2011 09:06 PM
I've got a rivet, I've got a rivet! wannastream Our Community 9 03-17-2007 08:27 PM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 04:41 AM
