Old 01-16-2019, 05:29 AM   #21
Edistobob's Avatar
2013 25' Flying Cloud
Edisto Island , South Carolina
Thanks for the suggestions. I'd like first to try the method least likely to make it any worse. Seems to me that would be the vacuum method; is that correct? What's the worst mistake I could make doing that? Also, twin bed is in that area so removing inside skin is an option I'll save to consider later. If vacuum doesn't work I think the suction cup tool from HF will be my second try. Any particular advice on the vacuum method, particularly since it is on a curved area?
Edistobob is offline   Reply With Quote
Old 01-16-2019, 05:46 AM   #22
2019 30' International
Pennsylvania , Pennsylvania
I would think the vacuum method challenge would be to keep the seal on the curved area. If that doesn't work, I'd contact some PDR folk.
I've had paintless dent removal (PDR)l done on vehicles, but not aluminum. Many Ford dealerships have access to local aluminum repair people as many new Fords have aluminum bodies. Car dealerships can also hook you up with local PDR guys. If it were mine, I'd have a PDR guy look at it.
majorairhead is offline   Reply With Quote
Old 01-16-2019, 07:22 AM   #23
Iansk's Avatar
1977 31' Sovereign
Sunset Valley , Texas
You could try using luaun or even bendable plywood to match the curve. If using luaun, perhaps make the sheet longer width wise to facilitate bending but keep it just wider than the tube you are using height wise. Make sense?
Of course you’ll need to grow a third hand if you don’t already have one.
Ian
Iansk is offline   Reply With Quote
Old 01-16-2019, 08:58 AM   #24
DaveP's Avatar
2004 28' Classic
Monument , Colorado
2X the PDR. It is the lowest risk as it will certainly cause no increase in the damage. It also has the highest probability of giving you a satisfactory results. If you start messing around with the dent, you may make it worse and harder to repair with PDR, IMHO.
My DW's car has an aluminum hood. Her car was damaged in a big hail storm 2 years ago. The PDR method was used on the hood and the results were perfect.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 01-16-2019, 09:24 AM   #25
HowieE's Avatar
Princeton , New Jersey
Images: 12
The inner tube method will work on larger dents. Since you can only approach one atmosphere with that method it will be more effective over a larger area.
If you attempt the suction cup method I would suggest 2 cups one on either side of the crease since you will not get a seal across the crease. If you can seal 2 cups I would not pull on them as much as rotate them outward at the crease.
2004 Excursion 4x4
Old 01-16-2019, 10:02 AM   #26
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
I used a toilet plunger to get a similar one out. It does not help the crease, but the dent is much less noticeable. And it was cheap. Little harm in trying.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Old 01-16-2019, 01:01 PM   #27
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Replace the panel.
Old 01-16-2019, 04:36 PM   #28
2016 23' Flying Cloud
Corpus Christi , Texas
Dent
My hubby had a dent and crease when backing it into storage. A car repair man came to the house and put some glue stuff on them and popped them out. Looks good.
2fromtexas is offline   Reply With Quote
Old 01-16-2019, 05:07 PM   #29
Mollysdad's Avatar
I vote for the paintless dent repair.
The guy will come to you, he has the tools and uses a light with parallel bars to show smooth.
I'd guess he'd start at the taillight to get inside, use a little heat, some massaging, and after that it's magic.
Old 01-16-2019, 06:04 PM   #30
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
You guys are probably right with the first try being PDR, however removing the tail light does not get you behind or between the skins, there us a bucket behind that seals the area.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 01-16-2019, 06:05 PM   #31
Bigventure's Avatar
Hinckley , Arizona
I had a dent just like yours. All it took was a small 1.5 suction cup to pop it out. I use one of those clear vinyl ones that you use to hang stuff from windows.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 01-16-2019, 07:01 PM   #32
The SilverSleeper
Beaubill's Avatar
2001 28' Excella
2005 25' Classic
1988 23' Excella
Daphne , Alabama
I had a smaller dent and I put a Woodstock yellow decal on it and you don’t see the dent anymore. Had a friend who had a larger dent and we put a large round Red reflector on it, it was on the side so we put another reflecctor on the other side, they looked like they belonged there. You might want to try a larger decal of some type to see if works. Who knows it might work and it will only cost a couple of bucks.$ just something to try
Beaubill is offline   Reply With Quote
Old 01-16-2019, 08:26 PM   #33
Edistobob's Avatar
Thanks for the additional suggestions. I'm talking to a PDR guy on Thursday-sent him some photos today. I've used him in the past for my cars. And I really like Bigventure's comments about the suction cup. Would be really nice if that could work. In any event y'all have given me some really good things to try.
Old 01-16-2019, 10:30 PM   #34
Night owls's Avatar
2018 26' Flying Cloud
Hemet , California
Ouch! Sorry I don't have any suggestions but just curious as to how that happened?
Night owls is offline   Reply With Quote
Old 01-17-2019, 04:43 AM   #35
Edistobob's Avatar
Momentary inattention on my part!
Old 01-17-2019, 08:49 AM   #36
Edistobob's Avatar
Just an update: talked to PDR tech and he is confident that he can get the main indentation out but probably not the crease. I told him I'd be plenty happy with that. So, in a couple of weeks we'll arrange to give that a shot. I'll post a photo of the "after". I'm sure that anything the tech can do will look better than what I'd likely do. BTW, he will be using pull techniques based upon his prior experiences working on Airstreams.
Old 01-23-2019, 12:10 PM   #37
Severna Park , Maryland
dent repair
If you are a "handy" guy, you might visit Eastwood products. They have a number of dent removal tools for the DIY'fers. Having performed auto restorations, I find Eastwood has a very good selection.
Here's a kit from Amazon....
https://www.amazon.com/Paintless-Dent-Repair-Tools-Kit/dp/B07FQDRFXJ/ref=asc_df_B07FQDRFXJ/?tag=bingshoppinga-20&linkCode=df0&hvadid={creative}&hvpos={adpositio n}&hvnetw=o&hvrand={random}&hvpone=&hvptwo=&hvqmt= e&hvdev=c&hvdvcmdl={devicemodel}&hvlocint=&hvlocph y=&hvtargid=pla-4584207578537375&psc=1
KenA
'08 VJ-24
MD
RedBird64 is offline   Reply With Quote
Old 01-23-2019, 01:35 PM   #38
1972 23' Safari
Middletown , Rhode Island
I gad a similar dent
I had a big dent a lot worse on my back corner of my 72 airstream which the PO got quoted $300 to fix but I spent about $11 on a suction cup dent puller and fixed her myself. See link post 9.
http://www.airforums.com/forums/f420...ri-156604.html
Mx468 is offline   Reply With Quote
Old 01-23-2019, 02:27 PM   #39
SLC , Utah
metal message
Look for a metal message tech. They are mobile most of the time and I have used. They will have a set of tools that allow them to apply light tapping outside and holding a plate inside while not dinging the metal surface. They change the plate often to assist in forming the metal shape back to the original They did a very good job on a ding that was a V and it came out perfect. I was amazed. Good luck.
MojoRisen is offline   Reply With Quote
Old 01-24-2019, 07:21 AM   #40
Bigventure's Avatar
Hinckley , Arizona
The problem with a lot of the suggestions, is dent removal guys need access to the back side. They can reach into fenders and doors. In addition aluminum is not steel. It has different flexibility.
I chose America
Which would you rather? Better brakes, better hitch, or better wheels/tires? bjmckernan General Repair Forum 30 07-17-2016 07:47 AM
Replace or leave well enough alone bongo Repairing/Replacing Floor &/or Frame 26 05-18-2014 08:04 AM
Couldn't leave well enough alone sluggo 1970-79 Tradewind 2 04-08-2008 10:21 PM
Seal or Leave it alone? aviontt Repairing/Replacing Floor &/or Frame 4 11-17-2003 08:04 PM
