RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 09-29-2019, 03:33 PM   #21
1987 34.5' Airstream 345
Auckland , New Zealand
I havn't managed to dent mine yet, only Luck so far ,but you got me to thinking....
If I knew definitely that the Rib was compromised ie pushed in somewhat, and was very noticeable, well I'd consider drilling out the Rivits along the dent to relive further stresses on the sheets and with access from inside put long set screws ie long thin bolts through, a wood chocked Steel Beam with same hole spacing's then nuts on inside, then with a spanner start n tighten.
Hopefully someone or anyone could tell If this folly or not? Done slowly with a good shock every so often from a ball pein to help set itself .
Duno just Duno???
Voltair is offline   Reply With Quote
ISO 74" Jackknife Sofa and Air Conditioner Libbitt Airstream Classifieds 0 11-24-2016 05:57 PM
Replacing jackknife sofa 30' no slide wheelygoode Land Yacht/Legacy Motorhomes 12 11-24-2016 01:08 PM
Sofa, jackknife 74" part# 702891-418 Bamagirl Airstream Classifieds 0 09-08-2014 11:06 PM
Jackknife to floor attachment dougandlori Repairing/Replacing Floor &/or Frame 0 11-27-2013 12:29 PM
2004 Safari 25' jackknife sofa Tom U. Interior Restoration Forum 1 04-13-2013 07:41 PM
