Old 05-02-2020, 05:30 PM   #1
1996 34' Excella
Laporte , Colorado
Is this repairable?
Does this look like repairable damage? How would you go about fixing this and what would you expect it to cost?
kbrasmussen is offline   Reply With Quote
Old 05-02-2020, 06:02 PM   #2
1960 22' Safari
in the wilderness , The great Mojave Desert
Is it repairable? You bet.
The lovely Mrs. Goin Camping After screaming "Ramming Speed" (<- I exaggerate.) backed into the same area on ours.
Dent came through to the inside. All exterior, interior panels and spars. 10K at Area 63 Productions. Could not tell it ever happened.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 05-02-2020, 06:05 PM   #3
dznf0g's Avatar
Oswego , Illinois
Hmmmm, I think it is every bit of $25k.
-Rich-
Old 05-03-2020, 01:09 PM   #4
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
Looks like two panels, banana/belly wrap, and trim. Without knowing what actually happened (looks like you dragged against something?), there's probably little to no damage to the interior, so theoretically it could be repaired without removing anything on the inside. If that's the case, you could be "lucky" enough to get away with around $5k. However, it could easily hit 10, 15, 25, depending on what we can't see from the pic.
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
kidjedi is offline   Reply With Quote
Old 05-03-2020, 03:03 PM   #5
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Talk to Jackson Centre,send them pictures of inside and outside and you will get a very close estimate of cost to repair. That looks like the trailer that was sold on one of the auction sites last month.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34' 1987 Limited 34'
1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 05-10-2020, 09:27 AM   #6
1996 34' Excella
Laporte , Colorado
Update
Quick update on this. We ended up purchasing this and decided it was with going through some major repairs. Luckily I have some handy friends. We ended up deciding to replace the entire tongue. Since the coupler was bent along with the a frame. We think that the trailer was jackknifed while going down the road. Maybe hit some ice?
As for the body work the front curved c channel is destroyed. Along with the rib that attaches to the c channel and arcs over the entire roof.
Does anyone have any tips to replace that c channel portion? Also, for the rib is it possible to remove just the damaged section and weld or reinforce a new section? I am hoping we don't have to replace the entire rib because that would mean we would need to entirely disassemble the front end cap. PHOTOS INCLUDED.
Old 05-10-2020, 09:31 AM   #7
1996 34' Excella
Laporte , Colorado
Photos for above post
Photos did not attach correctly. Here they are.
ID:	367589   Click image for larger version
ID:	367591   Click image for larger version
Old 05-10-2020, 10:00 AM   #8
2018 25' International
Slidell , Louisiana
No tips on the C channel but as for the rib, a competent welding shop can weld rib pieces together, you can also butt them and reinforce them with well fitted sheet bent to match on the inner rib sections. Or you can do a bit of both...
Brian
Old 05-11-2020, 01:53 PM   #9
kidjedi's Avatar
1972 25' Tradewind
1975 24' Argosy 24
Denver , Colorado
You can "sister" pieces together for the ribs. The strength comes in all the pieces being riveted to the skin (the semi-monocoque idea). You will often see "partial" (not all the way across or all the way down) ribs from the factory in 70's Airstreams.
Edit: ...and wow! As is so often the case, that damage was worse than it looked! Once it affects the frame, things start to get hairy.
BeahmStream.com
Old 05-12-2020, 01:30 PM   #10
1996 34' Excella
Laporte , Colorado
Thank you! This is helpful. Good news, the frame is not damaged. We just replaced the tongue for safe measure since it looks like it took a good hit.
1988 34' airstream excella repairable eBay Watch Airstreams on eBay 0 01-07-2010 08:20 AM
2009 airstream flying cloud /damaged repairable eBay Watch Airstreams on eBay 0 09-24-2009 10:40 AM
Original Power Tongue Jack Repairable or Replace? Cos Jacks, Stabilizers, Lifting and Leveling 2 05-11-2009 11:39 AM
Repairable or Totaled campcollector 1997 - 2004 Bambi 29 04-20-2004 10:30 PM
Is this awning part repairable/replaceable? Swingking Awnings 11 03-10-2003 10:43 AM
