Old 04-10-2019, 10:53 AM   #1
1953 25' Cruiser
kingsport , Tennessee
Interior wall - ribs at the front and back radius of trailer
I've taken my 53 cruiser down to just the frame and installed everything new from the outriggers to new floor and channels -ect - reinstalling / securing shell
My question is - as I am replacing vertical ribs - I noticed the vertical ribs that the exterior panels rivet to are not connected to the bottom floor or and channel - they kind of free float in the channel
This is common both under the front window and the same at the rear under that window as well
Is this due to the fact that the unit has to flex - or - should I attach solid as I have with all the others
Thanks much
kriskari4315 is offline   Reply With Quote
Old 04-10-2019, 11:11 AM   #2
1966 22' Safari
Fredericksburg , Texas
I ran into the same thing. Some of the primary ribs stopped shy of the C-channel. The horizontal stringers were also free floating. I asked Colin Hyde, who I think is one of the foremost authorities on Airstreams, whether I should rebuild as original or attach. He said to attach the ribs to the bottom and the horizontal stringers to the vertical ribs. Good, bad, or indifferent, thatís what I did. I understand how the semi-monocoque construction works, but felt attachment was a better mousetrap. I may get some popped rivets due to rigidity, but weíll see. Good luck
Bubba L is offline   Reply With Quote
Old 05-01-2019, 05:39 PM   #3
1963 28' Ambassador
Northern VT , Vermont
I ran into the same thing on our 1964. Made aluminum angle brackets for all and bolted through the floor. Prob 8 yrs now, lot of miles, many on washboard pothole roads. No poped rivets or problems of any kind.
putback is offline   Reply With Quote
Old 05-01-2019, 06:55 PM   #4
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I too have attached the ribs to the C channel and the ribs to the stringers. Iíve changed the shell structure quit a bit. No problems. Itís all outlined in my thread below.
Radius cutter 1/4" and 3/4" by Accucutter svanpelt Airstream Classifieds 0 03-22-2015 02:28 PM
Something between the interior skins and ribs? Airwave503 Ribs, Skins & Rivets 20 03-01-2015 07:31 PM
Turning radius and garage door walls RankAm Towing, Tow Vehicles & Hitches 12 05-27-2009 09:46 PM
Tips on backing up and Turning radius NewStreamer On The Road... 36 08-12-2006 08:27 PM
No Ribs in front & rear??? BornToRock Ribs, Skins & Rivets 0 08-28-2005 09:20 AM
