Old 06-16-2020, 05:20 PM   #1
mikeinca's Avatar
2020 25' Globetrotter
Santa Rosa , California
Interior rivet replacement question
So, I noticed that a rivet had popped out of the ceiling in our 2020 Globetrotter leaving a nice clean hole. I found a rivet repair kit on the Airstream store web site and no doubt overpaid for a rivet tool with a swiveling head, as well as a selection of replacement rivets and drill bits.
Using one of the 1/8" rivets with the correct 1/8" nose piece installed in the tool I followed the directions, keeping the rivet head firmly against the aluminum surface while working the tool handle. The instructions said to expect to work the handle 3-4 times and, sure enough, on the 3rd squeeze I heard a snap and the rivet was seated tightly in place. However, instead of a rivet with an empty hole as the instructions said to expect, there was a piece of the mandrel still stuck in the rivet. The remaining piece is pretty much flush with the rivet head and isn't real noticeable (if you don't look for it like I'm currently constantly doing) although I can feel a sharp burr with my finger.
Is this normal? I thought I was careful to keep the tool straight as I operated it but it's possible that I could have flexed it slightly so that the mandrel broke off instead of pulling completely out. I guess I could try using a punch to drive the remaining piece out or drill out the rivet completely and start over but both of those operations have their own risks and it may be best to leave well enough alone.
This was my first rivet replacement so I have no experience and am soliciting advice. Suggestions?
Mike
2020 25' Globetrotter Twin | 2017 F250 4x4 6.7 max tow Platinum
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
mikeinca is offline   Reply With Quote
Old 06-16-2020, 05:42 PM   #2
2018 25' International
Slidell , Louisiana
Normally the mandrel breaks at its weakest point where it is notched down at the neck by the head that expands the rivet shell so most of the mandrel is removed. Yours broke near the rivet head possibly because the gun was not straight but it could have been a manufacturing error in the mandrel.
If you use a punch you will drive out the mandrel head and it will weaken the grip.
I don't think it is worth drilling out and doing it over.....
Brian
Old 06-16-2020, 06:14 PM   #3
Globie64's Avatar
1964 19' Globetrotter
South Kingstown , Rhode Island
Images: 18
Are the other rivets smooth or do they have the mandrel hole? You can get a rivet shaver, another pricy but satisfying tool, and clean up the mandrel that way. Vintage RV sells them- omg, I just saw the price! I've made great use of mine, but it was less than half the cost... https://vintagetrailersupply.com/sha...ivets-vts-177/
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 06-16-2020, 06:42 PM   #4
KK4YZ's Avatar
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee , Georgia
It happens. Consider soothing the rough Ďstickí out with a dremel or something like it....carefully.
KK4YZ is offline   Reply With Quote
Old 06-16-2020, 06:45 PM   #5
2019 25' International
Providence , Senior Electrical Engineer
This is one example of why JC uses an air gun rivet tool to ensure it has a proper hard pull and snap. They only have so many of those guns but the tech told me that they only use that for interior rivets to ensure the mandrel doesn't do exactly what your describing.
I two two popped rivets on my 2019 when we were in JC for repairs and I watched them do it directly so I could learn to do it myself.....only problem is....the gun they use is north of $800. I plan to get one, but @$400 a rivet for cleanliness, I'll let JC do with while it is under warranty.
We have another popped rivet which they will replace when we go in July.
kittmaster is offline   Reply With Quote
Old 06-16-2020, 07:03 PM   #6
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
That rivet shaver is only for 5/32 Olympic rivets used on the outside, not 1/8 pop rivets. Just tap the broken mandrill lightly and it will move in and not affect the strength at all. They are meant to break off not pull right out.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 06-16-2020, 08:21 PM   #7
mikeinca's Avatar
Thanks to all for the info and advice. I think I'll try Shacksman's suggestion to gently tap the mandrel remnant in and see if it works. I'm a bit hesitant about using anything powered as I might end up with a worse situation than I have currently!
Mike
Old 06-16-2020, 08:30 PM   #8
Slidell , Louisiana
good luck, please let us know how it works out!
Brian
Old 06-17-2020, 12:12 AM   #9
mikeinca's Avatar
Thanks. I did try tapping the mandrel remnant in with a hammer and small punch, but without success.
When the tool broke it off it appears the mandrel got "pinched" so that it's no longer perfectly round and maybe for that reason won't recede easily into the rivet head. Anyway, I didn't want to press my luck by rapping on it too forcefully so after a few tries I decided to let it be.
With hundreds of rivets in the ceiling I'll likely be the only one to ever notice that one looks a little different than the others. At least I've learned something from the experience.
Mike
Old 06-17-2020, 08:47 AM   #10
2017 30' International
Charlotte , North Carolina
Other suggestions: get a small file and file the burr off the mandrel. Or, get a drill bit the size of the hole and drill out that rivet and put another one in.
Disclaimer that while I have put in and drilled out a good number of rivets in my time, I have not done so in the interior of my Airstream. I have about 3 or 4 I need to put in where the heads have popped off.
Al U. Minium is offline   Reply With Quote
Old 06-17-2020, 09:00 AM   #11
You can also use a Dremel with a stone grinder with a fine point and GENTLY AND SLOWLY remove the burr that way.
Just enough to hit the mandrel and maybe the rivet edge...with then can be metal polished and no one will ever tell/see the difference.
Old 06-17-2020, 11:02 AM   #12
mikeinca's Avatar
I do appreciate the suggestions and I've considered drilling out and starting over. But after reading a couple of the replies here it sounds like unless I use the special $800 tool, I might go to all the trouble, risk making things worse, and end up with the same result.
Although I can feel the burr with my finger it's not really noticeable. The issue (if you want to call it that) is that all of the other interior rivets have a hole in the center, while "my" rivet doesn't because the broken end of the mandrel is stuck in it. So, deburring and polishing won't really fix the visual "problem".
Maybe I can turn a lemon into lemonade and make a game of it; challenge visitors to see how long it takes them to find the interior rivet without the hole!
Mike
Old 06-17-2020, 01:53 PM   #13
1976 31' Excella 500
Chappell Hill , Texas
Let it be. Have a cool one and move on.
tbashin is offline   Reply With Quote
Old 06-17-2020, 03:31 PM   #14
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
This is only likely to happen once for every 100 rivets you replace. You were very unlucky to have it happen 1st time. Drilling it out with a 1/8 bit is quite easy, just tap the mandrel back into the hole and carefully drill it out and start again. I use a cheap Harbor Freight rivet tool and this has happened to me only a handful of times. To be honest, I think it has more to do with the quality of the rivet than the tool.
FWIW, for those of you who are experiencing regularly popped rivets, the likely cause is a rough-riding trailer. I dropped my tire pressures from the max 80 psi to 65 psi and that pretty much stopped the breaking interior rivets.
thewarden is offline   Reply With Quote
Old 06-17-2020, 05:04 PM   #15
gsmithii's Avatar
2013 30' Flying Cloud
Virginia Beach , Virginia
Life in the river lane
Expect interior rivets rivets to pop. Our 2013 will show me one or two loose or popped rivets from time time. Rough roads and time are likely to be behind it. A manual rivet tool is fine. Just take your time and be diligent to replace the rivets as soon as they are evident. The interior panels can move a bit when a rivet is missing. Itís just part of Airstreaming.
gsmithii is offline   Reply With Quote
Old 06-17-2020, 07:52 PM   #16
mikeinca's Avatar
Well, that figures....
I've tried tapping the mandrel back into the hole but it won't budge. Since it's protruding very slightly from the rivet head I'm concerned that if I try to drill it out the drill bit might slip and I'll have a much worse problem than I do now.
Mike
Old 06-17-2020, 09:23 PM   #17
2006 28' International CCD
City , Georgia
Rather than drilling out the rivet head and risk panel damage, itís very easy and effective to just knock the head off with a sharp wood chisel. Then you can push the rivet body out of the hole (I use an ice pick).
GotTaGo is offline   Reply With Quote
Old 06-18-2020, 02:11 AM   #18
Airstream Trippin
2020 33' Classic
Livingston , Texas
You have to take a 1/8th drill bit and drill out the remnants of the broken rivet first. Then apply the new rivet. I just replaced one over my dinette two weeks ago in my 2020 Classic.
Gigler is offline   Reply With Quote
Old 06-18-2020, 05:55 AM   #19
Ultraclassic's Avatar
2000 30' Excella
GTA , Ontario
Careful here, you can make a "small" burr on the rivet with a drill or Dremel/ die grinder/3m pad, into a "large" drill skip skid mark.
Try the centre punch trick first.
Also put some masking tape around it as cheap insurance if you skip off to the side, it might buy you space.
Like the saying goes something like this:
" I only wanted to drain the swamp, I didn't want to be up to my a$$ in alligators"
#4286 Stella the 2000 30ft Excella/Classic - Tow Vehicle - 2012 Mercedes Benz GL350d - CanAmRv.ca hitch Reinforcement EZ-Lift WD with 2 Anti Sway Bars. previous tow vehicle 2005 Ford F150 Lariat 367,000Kms 5.4L
Ultraclassic is offline   Reply With Quote
Old 06-18-2020, 01:53 PM   #20
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
Is it possible you were not able to get the rivet in and through the frame thus the mandrel had less material to compress, thus stick out.. Dremel and small stone grinder, is a good idea. You don’t need a $800. Tool, practice on some scrap metal, its not that difficult.
bibbs is offline   Reply With Quote
Interior "popped" rivet replacement? MAJORJDB General Interior Topics 16 06-15-2021 09:26 AM
Interior pop rivet replacement question DeltaRon General Interior Topics 12 06-17-2016 10:37 AM
Interior Rivet Replacement Process? interstateflyer General Repair Forum 3 06-23-2013 11:13 PM
To rivet or not to rivet? That is the question LavenderMoon Forum Admin, News and Member Account Info 3 03-24-2013 10:07 AM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 05:41 AM
