Old 06-07-2023, 03:01 PM   #1
2020 28' Flying Cloud
Jax Beach , Florida
How do I replace this rivet?
My 2020 FC 28 popped an interior rivet that is located over the overhead storage cabinet above the sink. It is inaccessible with my rivet gun. It is also a little weird in that it's not at a panel joint or in line with any other rivets.
As you can see in the pic, the rivet gun isn't going to work.
Any thoughts on how to replace?
gzvette61 is offline   Reply With Quote
Old 06-07-2023, 03:03 PM   #2
2022 25' Flying Cloud
Tualatin , Oregon
If you remove the cabinet door will you then have enough room for the rivet gun?
Steve
TitusNW is offline   Reply With Quote
Old 06-07-2023, 03:08 PM   #3
Jax Beach , Florida
No, the top of the cabinet itself extends about an inch in front of the rivet hole.
Glenn
2020 FC 28 RBQ
2020 F-250 Diesel
Old 06-07-2023, 03:14 PM   #4
Tualatin , Oregon
If the rivet hole is "covered" by the face frame of the cabinet then I think you're down to a sheet metal screw and one of the low profile ratchet screwdrivers.
https://www.amazon.com/MulWark-Profi...13564086&psc=1
Old 06-07-2023, 03:24 PM   #5
2014 27' FB International
Lewisville , Texas
I would just glue in a dummy rivet.
NO NOIZE is offline   Reply With Quote
Old 06-07-2023, 03:30 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
I would put a lath screw in
CRH is offline   Reply With Quote
Old 06-07-2023, 03:32 PM   #7
2002 19' Bambi
Lafayette , California
So would I.
Tim
Tim A. is offline   Reply With Quote
Old 06-07-2023, 04:45 PM   #8
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Rivet is there for a reason. - use a #8 ss sheet metal screw
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 06-07-2023, 05:21 PM   #9
baggs's Avatar
2013 23' FB International
aldinga beach , south australia
yup...screw it
baggs is offline   Reply With Quote
Old 06-07-2023, 05:26 PM   #10
dznf0g's Avatar
Oswego , Illinois
Do it once and do it right. I'd take down the locker and re-rivet. I guarantee you the locker mounting needs reinforcing anyway.
Sent from my SM-S901U using Airstream Forums mobile app
-Rich-
Old 06-07-2023, 07:07 PM   #11
StuartsDad's Avatar
2018 28' Flying Cloud
Chapin , South Carolina
I had same happen above our cabinet over the dinette. With some scrap 2x2's and plywood, I made a support for the cabinet so when I removed all the mounting screws, the cabinet didn't move. Slid the cabinet out a few inches to access the rivet. Slid cabinet back in place and reattached. With the cabinet doors removed, the frame is relatively light.
StuartsDad is offline   Reply With Quote
Old 06-08-2023, 02:02 PM   #12
2018 30' Flying Cloud
New Hudson , Michigan
Mine did the same, was at the factory repair center and asked them to replace it and they said they wouldn't, requires removing the entire cabinet and isn't hurting anything by not being there. Repair guy said it was common for those to pop because of the window awning on that side of the trailer (mine is a 30fb bunk) said if they did replace it it would likely pop again some time down the road.
ekbruster is offline   Reply With Quote
Old 06-08-2023, 02:32 PM   #13
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
I had same issue on my 23D (2017). Haven’t replaced it after 4 years and no issues.
Troutboy
Troutboy is offline   Reply With Quote
Old 06-08-2023, 06:25 PM   #14
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I find I always have one rivet that keeps popping out. I gave up on replacing it. Missing one rivet out of thousands isn't going to matter. Leave it or put in a dummy as suggested above.
2019 Ford Expedition Platinum
Old 06-08-2023, 08:20 PM   #15
Lewisville , Texas
Originally Posted by wayne&sam View Post
i find i always have one rivet that keeps popping out. I gave up on replacing it. Missing one rivet out of thousands isn't going to matter. Leave it or put in a dummy as suggested above.
:d:d:d
Old 06-14-2023, 09:12 AM   #16
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
That rivet is not really load bearing…except to tie two pieces of aluminum together. In all likelihood, it sheared off due to the two panels working back and forth. You can just about bet that if you go to all the headache of removing the cabinet and re-riveting it’s going to recur. I’d use a SS metal screw. Very tough metal. Having been at the Service Center multiple times, I’ve never had them miss a fix. Go with the guys who have built the trailers and “graduated” to repairing them.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 06-14-2023, 11:17 AM   #17
Night owls's Avatar
2018 26' Flying Cloud
Hemet , California
My 2018 26ft did the same exact thing in the same spot. Didn't bother to replace it and have had no issues in several years. I wouldn't worry about it.
Night owls is offline   Reply With Quote
Old 06-14-2023, 11:37 AM   #18
Texas Toaster
2019 27' Flying Cloud
Smithville , Texas
Steve
I had this same rivet problem on a 2019 flying cloud 27FB. Removing the door gave no better access. I even tried using a screw but Matilda no room.
MarkW is offline   Reply With Quote
Old 06-14-2023, 11:39 AM   #19
Texas Toaster
Smithville , Texas
Steve
I had this same river problem on my 2019 FC 27FB . Removing the door gave no better access. I even tried to use a screw with no better results. Still not repaired.
Old 06-14-2023, 05:24 PM   #20
Tualatin , Oregon
I've been thinking about this and wonder if something could be easily made to duplicate the action of the standard rivet puller.
I'm thinking of two plates. Insert the rivet through the top plate and secure the shank of a rivet with a twist so it wouldn't pull through the bottom plate. With full threaded bolts or all-thread and a couple of nuts, you could separate the plates which would set the rivet. Height of this "rig" should be small enough to fit between the cabinet and the roof.
Anyway, food for thought.
Steve
Name:	Manual Rivet Puller.jpg
Buck Rivet and Rivet BigGrey General Repair Forum 5 05-26-2012 09:29 AM
Rivet on rivet repair Darkspeed Ribs, Skins & Rivets 2 08-19-2011 04:46 PM
What to rivet, and where to rivet it? DanielB Ribs, Skins & Rivets 5 04-27-2011 09:06 PM
I've got a rivet, I've got a rivet! wannastream Our Community 9 03-17-2007 08:27 PM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 04:41 AM
