Old 07-22-2021, 08:04 AM   #1
2015 19' International
Cleburne , Texas
Help with patch
I have a rock guard hat tear. Iíve removed the hat and bought patch aluminum. Would you cut out bad section before repairing? Thank you.
mdebnar is offline   Reply With Quote
Old 07-22-2021, 11:11 AM   #2
1966 22' Safari
Fredericksburg , Texas
I donít see what difference it makes as long as there are no pieces of the tear that disallows the patch to lay firmly flat over the damage. Good luck
Bubba L is offline   Reply With Quote
Old 07-22-2021, 12:35 PM   #3
Mollysdad's Avatar
I assume we're looking at the trailer skin and not the segment protector(?).
After the patch, the "hat" will go back in the original spot? If so, I'd clean up the area where the screws will go (or rivets) and make the patch 50% bigger than the original area.
Is there a rib to screw into? or just sheet aluminum? Is there access from the inside? (may require a hole saw.)
Mollysdad is online now   Reply With Quote
Old 07-22-2021, 02:21 PM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I don't know what a"hat tear" is, but that looks like it has been repaired before. Maybe stop drill the cracks and then patch as Mollysdad said.
He said it was rock guard.
2019 Ford Expedition Platinum
Wayne&Sam is online now   Reply With Quote
To patch or not to patch... truckirwin Repairing/Replacing Floor &/or Frame 8 05-01-2014 05:18 AM
HELP! I don't know how to do a furnace patch robwok Ribs, Skins & Rivets 8 08-07-2013 08:37 AM
Body mods: To patch, or not to patch? Belegedhel Ribs, Skins & Rivets 0 01-05-2012 09:33 AM
Water line patch, or factory? TomW Fresh Water Systems 5 12-29-2003 10:14 AM
How do you patch Bullet holes? 59toaster Ribs, Skins & Rivets 5 10-26-2003 08:08 PM
