Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-30-2017, 08:50 PM   #1
noremark's Avatar
1992 32' Excella
Elma , Washington
Images: 12
Gearing up for the Exterior Makover
I will be getting married for the first time at the ripe old age of 57. She fell in love with me, not for my money (cause I aint got none) rather for my 92 Excella. Seriously, the honeymoon plan is a trip from Olympia WA to the redwoods via the Oregon’s coastline Hwy 101 to the redwoods, then on to Yosemite national park. May 5th is the date. So weather will determine the plans.
So any input there would be well received. (I mean as far as the trip! I GOT THE REST)
The interior has been completed last summer and now it time for the shell. I need to two areas and then strip and polish.
I have read many post (to many actually cause I am swimming in directions) but I will post my progress. First wanted to share my plan. Just in case I am headed for a cliff. PLEASE speak up. I am under the gun to get her done.
Here is my purchase list
Rivet Removal tool w/ # 21 spare bit
Olympic shave-able rivets 5/32
Cleco Sheet Holders / Cleco pliers
Shaver tool for Olympic rivets
Noxon Spring combination punch
Trempro 635 polyurethane
PPG PR-5044 Stripper
Nuviet Nushine polish: f9, C, A. I will be purchas a Dwalt DWP 849x 7" / 9" Variable Speed Polisher with Soft Start for the first phase of polish, then of course a Cyclo Pro Mark II Polisher and finish off with.
Scaffolding package rolling 5 x 5 x 10’ with 30” side brackets to get over the roof area and work from.
OK big question after taking a segment apart do i use a double sided sticky tape to seem the units back together. I'm not getting how to seal the units without making a big mess.
If you don't have the time to do it right the first time where you gona find the time to do it a second time.
noremark is offline   Reply With Quote
Old 12-03-2017, 11:47 AM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
First you need both the #30 and the #21 bits for your tool. The Rivets are actually 1/8 and replaced with the 5/32. No need to sell to the larger size until just before the final installation of the new skin. Use a good quality poly sealant instead of the tape. There is no reason to use the tape anywhere, unless you want leaks.
Old 12-03-2017, 11:52 AM   #3
Aerowood's Avatar
Arvada , Colorado
I would also try a vacuum slide hammer or the inter tube method before I would resort to skin replacement. You might be surprised with the results.
Old 12-03-2017, 02:35 PM   #4
Central , Mississippi
I'm with Aerowood, the inner tube vacuum trick will likely pop out that dent in 5 seconds. I helped remove a much worse dent from a bird strike.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 12-03-2017, 02:52 PM   #5
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
And if that does not work..I would concider removing the interior end cap and pushing it out that way before a panel replacement. Maybe you have thought that through already though.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 12-03-2017, 05:44 PM   #6
Iansk's Avatar
1977 31' Sovereign
Sunset Valley , Texas
Yeah, pull push suck that dent out.
When I dismantled my '77, I discovered that it had a panel replacement and Olympic rivets were used. every, single, one, leaked...
I used several dozen on my first reno ('64 Silverstreak) and I check those often with a suction cup in one hand and a tube of Cap' Tolly's in the other.
Ian
Iansk is offline   Reply With Quote
Tundra / truck gear box gearing question ... nickclifford Tow Vehicles 22 09-25-2017 12:15 PM
Gearing up for a cross country trip Golden Girl Member Introductions 11 06-22-2015 04:48 AM
310 engine change diesel to gas, gearing question tevake Mechanics Corner - Engines, Transmission & More... 4 10-11-2013 06:16 PM
Newbie gearing up for spring AppleStreamr Member Introductions 20 03-10-2010 06:14 AM
2008 Safari SE 25FB interior makover kingfisher24 General Interior Topics 10 10-16-2009 06:30 PM
