Old 05-15-2020, 07:02 PM   #21
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Glad to help and we learn from others' mistakes as well as ours. Others have lots more knowledge about this than me.
Gene
Old 05-16-2020, 09:58 PM   #22
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
Originally Posted by crispyboy View Post
Glad my post was of - Argosy - Chesapeake help for you. The quarter panels on my trailer were dented in from road debris hit by the previous owner and the center panel was cracked from fatigue.
One other thing I did before putting back together is to put thick aluminum plating (1/4") inside the skin so the the lower awning support fasteners would have something meaty to sink into and distribute the wind load.
Since your frame is so open this would be a good time to run some stainless steel brake lines "just in case" you ever decide to go the electric over hydraulic brakes in the future.
Thanks Crispyboy,
You're preaching to the choir. I totally get what you mean. Even before I pulled the shell I had identified a long list of areas that I wanted to reinforce. The awning supports being among them. I'm also going to add support and extra meat to the aluminum around all of the ceiling fan openings and the AC opening so the screws have more to grab, to provide greater support and to fix the damage done by previous installations. I also like the idea of adding additional roof support. I've always been nervous when I've had to do anything on the roof.
All of the quarter panel rock guard mounts will be reinstalled with beefed up reinforcement. The PO that installed the quarter panel rock guards didn't realize the stress they'd be under. Nor did they think to install the upper midsection fasteners. Four years ago, I discovered that the rock guards were actually wearing groves into the upper front midsection of the quarter panels. Not knowing what else to do at the time I attached some 1" thick, dense foam pads to the qps just behind the upper midsection of the rgs and that stopped the rubbing. At that time we were on the road in Pie Town, New Mexico which is a long way from everywhere. I’m not sure why but first I noticed the upper rg curbside fastening post that is located on the upper rear curbside edge seemed to be pulling loose. Well, it wasn’t pulling loose. The skin was splitting around it. When I removed the shell I could easily see the problem. AS had installed a separate sheet of reinforcement skin behind the qp and the “blind” rivets had missed it on one side of the mount. Road vibration and weight stress did the rest. Anyway, at the time, that led me to find the rub damage as well. Now I know that the same post can be mounted in addition at the upper midsection of each rg for added weight support and to secure that area as well and prevent the rubbing .
I believe I saw them being used like that in your photos. I'll be adding those and additional backside reinforcement. Naturally I'm actually going to have to put an exterior patch where the upper curbside rg fastener goes.
[IMG]https://lh3.googleusercontent.com/7Z...sYUEKnyPE=w400[/IMG]
We have a rear awning that literally pulled off in my hands while we were removing the rear window to replace the gasket. It had been installed with blind pop rivets or maybe it was screws, or both, I can't even remember at this point. It must have been added post build. Fortunately that happened after we'd separated the shell and was in full on restoration mode. I do remember that the holes it left were obscenely oversized. We love the rear awning, So, that’s a repair and reinforcement. We actually replaced the awning canvas on the rear and street side awnings three summers ago when I polished the exterior.
Please explain what you are referring to concerning the brakes. Are we talking disc brakes?
Here is a more current picture of the frame. It's hard to see, but the ribs are still open, however the rest is sealed by the floor and belly pan.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500
Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 05-16-2020, 10:08 PM   #23
Re-Pete's Avatar
1992 29' Excella
Originally Posted by ALUMINUMINUM View Post
Hello,
Your frame is beautiful, adding a front hold-down seems inevitable.
A hand-held variable speed electric shear in the style from Bosch, Milwaukee, Harbor Freight and some others, became an indispensable tool to my 68GT build. They are very safe, accurate, quiet, and comfortable to handle.
Not likely that you'll ever regret having one at hand.
ALUMINUMINUM,
Thanks, I agree, I definitely need a good electric sheer. I bought a pneumatic nibbler from HF, to cut out my side wrap. None of the cuts will be visible which is good because while not horrible, many of them aren't great.
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
34' Front End Shell Separation oldfulltimer Repairing/Replacing Floor &/or Frame 6 04-06-2014 04:34 PM
shop repair of 1970s rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 09:16 AM
DASH DIVING on 84 Excella 270 - Advice Sought N2XBW Classic Motorhomes 6 12-13-2007 05:34 PM
Simple Generator Needs Advice Sought scooterpie Generators & Solar Power 25 08-12-2007 02:18 AM
Newbie - advice sought. dbmarshall Our Community 10 10-11-2002 02:38 PM
