Old 12-18-2022, 11:04 AM   #1
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
Exterior river missing
How often do exterior rivets need replacing?
- Stewart
s1000pre is offline   Reply With Quote
Old 12-18-2022, 11:21 AM   #2
2018 25' International
Slidell , Louisiana
Ideally never, but it happens. Are you having other interior items coming loose also? If so look at your tire pressure (trailer and tow vehicle) and your WD tension. Might want to make the combination a bit more forgiving. Given the location, it also could have been stress from a slamming door or too much tension on the stabilizer jacks, just food for thought.
Old 12-18-2022, 01:26 PM   #3
2002 19' Bambi
Lafayette , California
Buy a few Olympic rivets, goop up the hole and the rivet with gray Sikaflex (https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1), and insert and seat rivet. The wipe off all of the squeezed out Sikaflex and again wipe that area with a paper towel or shop towel wetted with alcohol (uncured Sikaflex wipes off with alcohol). The Sikaflex left inside will prevent leaks and, because it is flexible and a good adhesive, will help prevent the same thing happening again.
Tim
Tim A. is online now   Reply With Quote
Old 12-18-2022, 03:34 PM   #4
s1000pre's Avatar
Any idea what size Olympic rivet?
- Stewart
Old 12-18-2022, 03:39 PM   #5
s1000pre's Avatar
I think it’s dumb luck. My weight dist is good and I only run my stabilizers down to the point of connecting with the ground, nothing more.
- Stewart
Old 12-18-2022, 03:41 PM   #6
2022 25' Globetrotter
North AL , Alabama
Should be 5/32" and a #20 drill bit if required.
https://www.vintagetrailersupply.com...f-100-vts-179/
Tyler2you is offline   Reply With Quote
Old 12-18-2022, 03:48 PM   #7
Slidell , Louisiana
In any case, it's unfortunate, particularly if you don't have a rivet gun and head shaver suitable for olympic rivets. I think the hand operated guns are about $45-50 and the shavers are in the $200-300 range. I think 5/32 is the right size but I am not certain. The Airstream manuals give the correct sizes in the maintenance section.
Old 12-18-2022, 03:56 PM   #8
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Warranty item?
Stewart, is this on your 2021 trailer? If so, shouldn’t that be covered under warranty? Something the local dealer can take care of at no cost since the tools are pricy.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 12-18-2022, 04:22 PM   #9
2004 22' International CCD
Beaumont , California
Use a regular aluminum rivet, SikaFlex or gray RTV the rivet before it goes in, then fill the hole with same after setting the rivet.
It ain’t kosher, but the cost of tools for me ain’t worth it for one or two rivets. You can’t see it unless you look for it, anyways.
Or, do it like original.., your choice.
Ndcctrucks is offline   Reply With Quote
Old 12-18-2022, 07:06 PM   #10
s1000pre's Avatar
Yes, it’s my 2021. The good news: I just met a fellow Airstreamer in Key West who has the tools, and willing to help replace the rivet tomorrow.
- Stewart
Old 12-18-2022, 08:08 PM   #11
2002 19' Bambi
Great that you found somebody to help.
The tools need not be expensive. Serviceable "pop" riveters are available for about $10 to $20 on Amazon and they will set an Olympic rivet. For a single Olympic rivet, a shaver is not necessary. A little work with a file or rotary tool will smooth out the rivet head adequately. Will the job be perfect? No, but it will not be visible from more than about 5 feet away.
Attached is a picture of the replacement porch light I installed in place of the original on our trailer. The aluminum patch is held in place by Olympic rivets smoothed out without a head shaver.
Tim
Name:	Tim A. Step Light.jpg
Old 12-18-2022, 08:44 PM   #12
Slidell , Louisiana
That's good information to know Tim, thanks. I have a super cheap manual rivet gun, guessing an upgrade would be worthwhile, but in a pinch it may work.
Old 12-19-2022, 05:52 AM   #13
1972 25' Tradewind
St Clair County , Michigan
How often should they be replaced?
As often as they come out, and no sooner.
TR Anderson is offline   Reply With Quote
Old 12-19-2022, 02:17 PM   #14
2017 25' International
West Lake Hills , Texas
A trick worth mentioning...
Each bag of rivets I carry contains the drill bit needed to install the rivets in the bag.
Fungus is offline   Reply With Quote
93 Classic Limited exterior snap sockets missing wanatrail Windows, Doors, Locks & Vents 0 10-22-2020 08:03 AM
Missing title, missing VIN in Texas. kristinatx Title, VIN & Registration 33 02-22-2016 09:54 AM
Missing exterior rivet Pedecanada Ribs, Skins & Rivets 31 02-14-2013 10:23 PM
Exterior door repair and missing screen door trailer-tras Windows, Doors, Locks & Vents 4 12-23-2011 03:40 AM
Missing Exterior Rivets carls017 Ribs, Skins & Rivets 5 10-13-2003 09:55 AM
