Old 04-12-2021, 01:51 PM   #1
Hillsboro , Oregon
Exterior door skin
Iíve seen a few builds that detail replacing the interior door skin, but not the exterior skin. Has anyone reading this ever done it, or know if a build thread that shows it? Iím terrified to take mine apart to replace the skin, but the edges of my door are all bent inward and I havenít had any luck straightening them with a hammer and dolly
Warden Brown is offline   Reply With Quote
Old 04-12-2021, 03:02 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
It really isn't that different than an interior skin, at least on an Airstream. We dismantled ours awhile back...I would just take lots of pictures on how things are taken apart to refer to when putting it back together. Also, label everything & use the old panels for templates for new/replaced panels. Good luck!
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 04-12-2021, 10:40 PM   #3
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
I agree with InsideOut its not that much different than doing the inside skin. It's my next project to do in June. I face two items that require the most planning.
Deciding how to finish out the bottom of the door. (My door had been damaged prior and the lower section was spliced in poorly and I believe it goes down too far.)
Name:	Current door bottom patch 1.jpg
ID:	393088 Click image for larger version
Name:	Current door bottom patch 2.jpg
Second, to get the edge beaded to match the original. I have the bead roller, but I'll make new dies.
Name:	Door Beaded Edge.jpg
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is online now   Reply With Quote
Old 04-28-2021, 03:06 PM   #4
Hillsboro , Oregon
I'm thinking about using a thicker skin on the door than what's currently there, so that it's less likely to bend in the future. Would there be any disadvantages to that?
Skin cracks lower corner of exterior storage door Wconley Ribs, Skins & Rivets 5 06-20-2020 05:33 PM
interior skin scrap for exterior skin patch? whatsherface Ribs, Skins & Rivets 1 06-12-2010 07:56 AM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
Exterior Skin Repair petemoss Ribs, Skins & Rivets 0 10-26-2006 02:49 PM
Type and thickness of exterior skin? reece1107 Ribs, Skins & Rivets 6 02-19-2006 05:23 PM
