08-14-2020, 01:17 PM
2018 33' Classic
Thousand Oaks
, CA
Dimple on roof
Is this an easy fix
08-14-2020, 01:28 PM
2021 30RB Classic
Saint Augustine
Maybe. Large suction cup dent puller. Something like this:
https://www.northerntool.com/shop/to...474bc140f2e8cd
Current: 2021 Classic 30' RBT
Past: 2019 Flying Cloud 27' FBT
WBAC 9602
Instagram: Cirrusaly.Silver
08-14-2020, 01:55 PM
2007 22' International CCD
Corona
Dimple on roof
Or try an softly inflated inner car or truck tube big enough to span the dent, a piece of 3/4 plywood that spans the inner tube outer diameter with a 1” hole in the center of the plywood to suck a vacuum on it with a sturdy shop vacuum.
Sometimes these pop right out with vacuum on top and atmospheric air pressure from below. Worth a try. Go easy on the vacuum at first and sneak up on it gently until the dent pops out.
08-14-2020, 01:57 PM
2009 34' Panamerica
2005 28' Classic
Still
, in the thick of it
The odds are you will only make it better, but it looks like it took a fairly good hit as off to the right is also dented.
Even with suction, the alum has already been deformed/stretched, it will always be there to some degree, but you can improve it, just don't expect anything grandiose.
08-14-2020, 03:06 PM
2002 25' Safari
Dewey
Ouch, looks like someone's knee
Richard
08-15-2020, 11:10 AM
Airstream Trippin
2020 33' Classic
Livingston
Originally Posted by candrews768
Is this an easy fix
Use a toilet plunger.
08-15-2020, 11:22 AM
1974 Argosy 26
Morrill
, Nebraska
Use the inner tube method. The dent is too large for a plunger. The plunger may cause a secondary wrinkle.
I am the one who came up with the inner tube method.
The dent in my Argosy was a bit larger. You would not know it was ever there.
08-15-2020, 12:01 PM
2009 25' FB International
2018 27' Globetrotter
Tavares
Is this on a unit you are considering buying? If so, get a discount and you could always leave it as it is if repairs do not work as planned. Could always use it as a conversation starter!
08-15-2020, 12:29 PM
2022 20' Basecamp
1968 17' Caravel
Los Osos
We used Dent Pro Mobile to remove an almost identical dent/dimple. The technician had a selection of suction cups. From experience, he knew which to choose.
It was so quick and easy to fix that he didn't charge us. There is still very slight evidence of the dent but difficult to see from the ground.
The alternative is to remove and replace the panel, a process that is intrusive and expensive.
08-16-2020, 09:26 AM
2018 33' Classic
Thousand Oaks
, CA
Thanks all. It was on the pre inspection report. AS says 2400 to replace panel. The RV dealer is going to fix it...33 FB classic.
