Old 11-20-2017, 03:10 PM   #1
Fullerton , North Dakota
Dent
Need advice on how to repair this dent. We will need to replace the cover on the bumper storage but how should we fix the dent that happened when backing into storage. The tail light wasn't damaged and lights work. The bumper did get scratched but not dented. I did contact the airstream dealer..but it has been 2 weeks and I still don't have any estimates from the dealer. Looking for options. Thanks.
ID:	299518   Click image for larger version
LWinters is offline   Reply With Quote
Old 11-20-2017, 04:01 PM   #2
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Check to see if the tail light housing can be removed. I am not familiar with that style of light, and possibly another member can advise. If it can be removed, you may be able to access the dent from the back and push out. Another option is to use suction cups and pull it out, or the hot melt glue pull. Often the paintless dent removal guys can do magic with this type of dent. Check with your local "good"body shop. Good luck, Chris
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34' 1987 Limited 34'
1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 11-20-2017, 09:42 PM   #3
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
I agree pull the tail light and see how much room there is to push and pull on it. You may be surprised how much of it you can get out.
1973Argosy is offline   Reply With Quote
Old 11-20-2017, 10:44 PM   #4
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
GVA , British Columbia
Insurance Claim
My 2 cents, that's a insurance claim and you need to replace that rear quarter panel anything less will look like a hack job. My estimate?? ,you are probably near 3-4 g's Sorry for the bad break.
Laurence
LAWBC is offline   Reply With Quote
Old 11-25-2017, 08:52 PM   #5
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
Send pictures to Airstream Service and they will tell you how much. IIRC mine cost about $7,000, but insurance bought their estimate and never came and looked at it. Just paid up.
guskmg
Old 11-30-2017, 12:58 PM   #6
Homedale , ID
I do airstream body work for a living that is going to require a new segment would never get rid of creases and dimples other wise gonna set you back 3000 to 3500
Airtech is offline   Reply With Quote
Old 11-30-2017, 01:16 PM   #7
2007 22' International CCD
Try a 'paintless' dent repair outfit. Some have reported success pulling out dents much worse than that.
Others have used an inner tube and a sheet of plywood plus a shop vac to use a vacuum to pop the dent. it does not look badly wrinkled, so its a possibility.
Search the forums for more data...
Old 12-11-2017, 01:02 PM   #8
2007 27' Classic FB
Ridgefield , Washington
Images: 11
How did this happen?
John
Woosch is offline   Reply With Quote
Old 12-11-2017, 01:09 PM   #9
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
Ten bucks.
Acheron2010 is offline   Reply With Quote
Dent Removal uwe Ribs, Skins & Rivets 11 01-17-2016 02:48 PM
Dent Pullers wagsrp Ribs, Skins & Rivets 12 07-30-2009 08:14 AM
The dent, another question... Kistler Our Community 1 08-24-2003 01:40 PM
Dent removel - two methods j54mark Ribs, Skins & Rivets 13 04-18-2003 12:52 PM
Dent Repair Jim W Ribs, Skins & Rivets 3 05-07-2002 12:43 PM
