Old 09-12-2018, 12:51 PM   #1
2005 19' International CCD
Phoenix , Arizona
Dealer Skin Replacement ?
Hi All. Hoping for some advice regarding a large panel of skin replacement by a local dealership. Our local dealer has said they will replace the lower curb side panel on our 2018 FbT International, but I am feeling very uneasy about their ability to do so correctly. They say they are Airstream certified but I am worried if not done properly or as to factory standards that I will have more problems down the road, such a water leakage.
Any advise or experience from others are appreciated! Thanks in advance. P.S. This repair is necessitated due to a scratch on a new airstream.
DAHBABY is offline   Reply With Quote
Old 09-12-2018, 01:03 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Photo of the 'scratch'?
A surface scratch with little panel deformation..now wait for it, we realize that as a new owner this may be hard to swallow...live with it. 😂
“Time will bring to light whatever is hidden; it will cover up and conceal what is now shining in splendor. “
Horace
If serious consider the factory. The very least call them.
Tahawus
Love for the Adirondacks
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on fire.
RLC
Old 09-12-2018, 01:22 PM   #3
Phoenix , Arizona
Thank you. You're correct that it just HURTS more than it looks. IF, the damage was done by someone else, then how would you handle? For instance, what should I expect "in lieu" of the repair? My apologies, I do not know how to attach a photo...but the scratch is deeper than the clear coat and about 4 inches long..... ugh....what to do..
Old 09-12-2018, 01:34 PM   #4
AlanMcD's Avatar
Cincinnati , Ohio
Just had panel repair done at the factory myself...don't ask... My thought for you is corrosion-X the scratch, then clearcoat, then make an appointment for the factory for when you may be out that way, even if it is years away. A scratch isn't that bad and if you can get to the factory on a vacation trip in a year or two perhaps that's the way to go.
-Alan
Cincinnati, OH
Blog: https://alanandcarie-airstream.blogspot.com/
AlanMcD is offline   Reply With Quote
Old 09-12-2018, 01:36 PM   #5
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
You're generally better off having the work done at an all-Airstream dealer like Airstream of Scottsdale. I would ask to talk to the technician who would do the work and see if he/she seems knowledgeable and experienced with panel replacement.
SilverWind is offline   Reply With Quote
Old 09-12-2018, 01:45 PM   #6
Phoenix , Arizona
The factory did say that the aluminum could not be repaired because the deep nature of the scratch...and that is why we are even contemplating replacement. Click image for larger version
Old 09-12-2018, 02:38 PM   #7
Well that looks very much like what happened here. 😢
The 'damage' is still their, but the hurt has subsided over time. 👍😂
I would....Negotiate for $$ compensation, and or an option upgrade.
Tahawus
RLC
Old 09-12-2018, 03:03 PM   #8
Phoenix , Arizona
Thanks for your thoughts! Much appreciated.
Old 09-13-2018, 10:20 AM   #9
2006 30' Classic
1966 20' Globetrotter
Dover , Delaware
One thing to consider even if you have the factory replace the panel it will not be as good of a job as when it was built. No one can put it back exactly like it was. If the damage is minor try and live with it.
helwigc is offline   Reply With Quote
Old 09-13-2018, 10:30 AM   #10
Santa Rosa , California
Vinnie's North Bay Airstreams - Wilton, CA - best in the business, it will be like new. Recommend doing it in the Winter when he slows down a bit.
JohnCaliAS is offline   Reply With Quote
Old 09-13-2018, 10:42 AM   #11
Rgentum's Avatar
2016 27' Flying Cloud
Olympia , Washington
While crossing the White Salmon/Hood River Bridge, across the Columbia River, I was forced out of my lane by a rent-a-truck/trailer combo and hit the bridge's guardrail --- see photos.
I took the trailer to Airstream Adventures NW, outside of Seattle and had them do most of the work --- see note below. They assured me that they had a guy who had taken numerous classes at Jackson Center about replacing aluminum panels. I met and talked with him, an older fellow who sounded like he knew what he was talking about.
I came back several weeks later. WOW!!! A new Airstream --- you never would have known.
Note: The estimate for the total repair was approx. $16.5K. I declined to have the door replaced and the right front rock guard replaced, resulting in approx. $9K of work. The door continues to show a small scratch. The rock guard I easily hammered back, so that it looks virtually new.
Name:	AS Dent 1.jpg
ID:	322375   Click image for larger version
Name:	AS Dent 2.jpg
Name:	AS Dent 3.jpg
ID:	322377   Click image for larger version
Name:	AS Dent 4.jpg
Alta & Richard, Olympia, WA --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 09-13-2018, 10:45 AM   #12
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
skin replacement
Just know that an Airstream dealer doing the replacement is backed up by Airstream! It won't be cheaply done and will be warrantied for at least some period of time. Not so much at some multi brand dealership. If you can live with the scratch why would you bother with breaking loose all the factory sealant between the panel edges and openings just to get a shiny scratch free panel and take the chance on future leaks! Go to a graphics store and have an appropriate sized Band Aid decal made. That makes it a good camping story for years to come! Ha! I guess my advice would be get a repair estimate from your closest Airstream dealer and have the person responsible for the damage pay that estimate and damage costs. No one ever says you must repair/replace to be reimbursed for you loss. Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 09-13-2018, 11:01 AM   #13
2014 27' FB International
Sugar Land , Texas
I faced this problem and declined to replace the panel. To attache the new panel they will likely use a special "Pop" type rivets provided by Airstream. Airstream built your unit with "Bucked" rivets which requires access to the inside of the trailer. I was told that the replacement pulled rivets have a hole that is filled and the rivet shaved so that the rivets resemble the original factory rivets. I am sure that the factory supplied replacement rivets are sufficiently strong when properly installed. On this forum someone suggested a spray on product called Nyalic. I have used it on scratches and it is effective in making minor scratches less noticeable and protects the exposed aluminum. It is transparent but does leave a surface shine. Can't say how long it will last. Best of luck.
us3rnam3 is offline   Reply With Quote
Old 09-13-2018, 11:44 AM   #14
2018 19' Flying Cloud
Newport , Washington
Earlier this summer I managed to jackknife our Bambi and put a dent in the curb side front just below the window. I didn't even notice it for 3 days but now it really bugs me. My dealer (Airstream of Spokane) is awesome to work with and I would trust them to do a panel replacement. Going to the factory is out of the question due to distance. While I know the dealer would do a wonderful job I am concerned about breaking the seal that was put on the inside after the outer shell was assembled. My dilemma is that I'm also concerned that this dent, although hardly noticeable, will have a serious effect on resale value down the road. If I have the panel replaced then my insurance takes the hit. If I leave it as is then when we sell/trade the unit we take the hit.
Not sure if I should leave it well enough alone or have the panel replaced. Thoughts?
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
KelloggKid is offline   Reply With Quote
Old 09-13-2018, 01:48 PM   #15
1976 31' Sovereign
Oswego , Illinois
Thumbs up
I don't agree than as good a job as when built. First place they rarely take whole skin off but over lay new over old even if to replace uprites, they just cut hole to access part to replace damage. then over lay. Seal replacement skin same as when new then use olympic rivets if can not get inside to buck rivet. Olympic just as strong IMO. and very few can tell dif. if not well versed and how to tell. I have used many olympics and not many can see where they were used. I have had repairs done at JC 3 times over the yrs. on 3 dif. corners and that's how it was done. Very satisfied And I'm a perfectionest. If dealer scratched before delivered it's there dime to fix, if you did it either turn into ins. co. or bite the bullet pay out of pocket and panel replacement is costly, or some suggested some kind of decal or some other kind of band aid or live with it. Yes it hurts if you did it but you will forget about it over time, bottom line use AS and enjoy as prob. not last scratch will get.
Old 09-13-2018, 02:10 PM   #16
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
I've just had some other repairs done at Windish RV in Lakewood/Denver. They are a 5-Rivet dealership that suffered some extreme hail damage to their own inventory. All repair work was done by their team onsite. If I had to get panels replaced, I would make the journey to go there and have it done.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 09-13-2018, 02:34 PM   #17
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
There are dealers and there are competent dealers. In my experience, I would not let the Scottsdale dealer change a light bulb because if the ancillary damage and mess when we had a simple project go really south.
There are third party vintage trailer restorers that replace skin all of the time. I have used A&P Vintage Trailer Works in Paradise TX for extensive modifications to both our 2014 31’ Classic and 2015 23D International Serenity. Have seen them do frame off work on 40s vintage trailers where everything but the skin is made new.
Just saying....
2014 31' Classic model 30 twin beds, 50 amp service, 900 watt solar system, Centramatics, Tuson TPMS, disc brakes, 16" tires & wheels
Old 09-13-2018, 06:22 PM   #18
Anna Maria , Florida
The dealer will tell sure we have factory trained technician.
Anything goes wrong you will never know. They will cover it up.
I had two full lower panel replacements both by the factory. I would not trust a dealer especially the street side panel. Of course I am only three hours from JC.
franklyfrank is offline   Reply With Quote
Old 09-13-2018, 06:47 PM   #19
sb55's Avatar
2018 30' Flying Cloud
South Hero , Vermont
A long a no rivets are pooped, how about a custom taller rock guard?
sb55 is offline   Reply With Quote
Old 09-13-2018, 10:04 PM   #20
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
FWIW, At the factory all late model Airstream repacement skins are cut on their computer control cutting table by serial number. If you need a new side, they just put in the serial number and in an hour or so your new panel ie delivered to the installing tech. That means when he fits it on it will be a perfect fit for your trailer. The reason for overlay in the past was because the Vulcum they used was impossible to completely remove. Now after removing the old panel they seal tape the new piece, rivet it on and caulk the edges. It is now really just like new. However, I now have both lower side panels replaced with the old system and you can not tell they are not OEM. Airstream Service Center does it right the first time.
guskmg
MSRP Varies Dealer to Dealer? Rounder44 Dollars & Cents 12 09-06-2018 07:01 PM
Airstream dealer vs MB Dealer rtdavew Sprinter and B-van Forum 13 06-10-2018 01:49 PM
To Dealer or not to Dealer, that is the question Johnsito Brakes & Brake Controllers 7 07-27-2013 10:11 PM
interior skin scrap for exterior skin patch? whatsherface Ribs, Skins & Rivets 1 06-12-2010 08:56 AM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 05:50 PM
