Old 07-22-2022, 05:55 PM   #1
2018 23' Flying Cloud
Eagle Creek , OR
Send a message via Skype™ to almcate
Bird strike repair
Have a bird strike directly above the letters of the AIRSTREAM nameplate. Hoping to avoid an expensive and lengthy shop repair. No hard crease, but it slightly deforms the letters lifting the edge of a couple letters. Is it reasonable to assume the letters are glued and not attached by rivets that might now be prone to leaks? Thinking that this might be popped with an inexpensive DYI suction cup dent puller... or failing that with something more sophisticated at a automotive body shop. Not the handiest guy, so looking for any advice or similar problems solved.
ID:	419841   Click image for larger version
Question: better to be a successful pessimist or a failed optimist?
Al & Robin
2018 Airstream 23FB Flying Cloud
2015 F150 XLT 3.5L EcoBoost, 4WD
almcate is offline   Reply With Quote
Old 07-22-2022, 06:18 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
It can be made to look a whole lot better with a pneumatic dent puller.
Being that is a newer trailer, I would probably consult with the local paintless dent repair guy.
CRH is offline   Reply With Quote
Old 07-22-2022, 07:28 PM   #3
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
That was a big friggin' bird!
SuperTrouper is offline   Reply With Quote
Old 07-22-2022, 07:35 PM   #4
dznf0g's Avatar
Oswego , Illinois
I think I would start with the inner tube/ shop vac method. See what pops.
-Rich-
Old 07-25-2022, 05:01 PM   #5
Eagle Creek , OR
Yep, it was a BIG bird...thinking maybe a hawk? Luckily a glancing blow off the corner of the cab's windshield (without TV damage) which took out some of the punch before it smacked into the AS.
Is there any concern about the loosened letters pulling free and creating a water entry point? Don't know if nameplate letters are attached through the skin on the backside or are glued to the skin surface; if the latter, any suggestions how to reglue after the dent is popped out?
Al & Robin
Old 07-25-2022, 05:14 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
I am pretty sure those letters are just held on by adhesive. You can reapply them with 3M VHB tape.
Old 07-25-2022, 05:21 PM   #7
2018 25' Flying Cloud
Newberg , Oregon
This video (skip to 4:50) will likely answer your question about how the letters are attached:
I bet that panel could be pushed or pulled near-perfect. If the inner tube trick doesn't work, you may need to consider removing the bedroom shelves and the interior panel to get access to push that out. Or, given that the interior panel is covered by the bedroom shelf, cutting a temporary access panel may also be an option.
starlite29 is offline   Reply With Quote
Old 07-25-2022, 06:46 PM   #8
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Definitely research “PDR” Paintless dent repair.
Call a few places local to you and ask if they have worked on Aorstreams/Aluminum . A good person will get that very nice. Don’t try on your own unless you are confident.
https://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowboarding habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Bird strike Knuff On The Road... 13 01-09-2018 05:05 AM
Rivet Type - Door Strike Plate bganso Doors & Locks 2 03-14-2012 10:33 PM
Strike three.......... Robbie R. Buyer Guidelines 20 08-21-2009 12:50 PM
Will Someone Please Sell Me A Strike Plate Navigator Doors & Locks 3 10-31-2005 06:10 PM
Bent strike plate mtpalms Doors & Locks 7 10-31-2005 04:02 PM
