Old 04-03-2020, 01:20 PM   #1
Rosemary beach , Florida
Are these dents fixable?
I found a trailer I'd like to buy, but only if the dents can be fixed. Normally I wouldn't consider anything with exterior dents, but this is a 1952 Silver Streak Clipper, the one with "alien eyes". Are the dents fixable? Can they be knocked out from the inside? If not, would it cost a fortune to replace the damaged panels?
Tikidog1102 is offline   Reply With Quote
Old 04-03-2020, 02:13 PM   #2
Iansk's Avatar
1977 31' Sovereign
Sunset Valley , Texas
Howdy and welcome...
Those are fixable to a degree via encouraging them out from the inside but they'll never be perfect. If you were to do the work, both removal and reinstallation of the panels, you could get a sheet metal shop to fabricate new panels for a fairly reasonable price.
Those are awesome trailers and very much deserve to be brought back to life.
Do you have more pictures?
Ian
Iansk is offline   Reply With Quote
Old 04-03-2020, 02:34 PM   #3
1967 17' Caravel
Pocatello , Idaho
Keep in mind that replacing the panels might be problematic if you intend to polish: have to get the same grade/kind of aluminum to get the same level of polish all over, I believe.
Yes, please: more pix!! What a find....
Vivian
Landshark is offline   Reply With Quote
Old 04-03-2020, 04:21 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I know a little bit about fixing dents. Dents where the metal is creased is not fixable as the metal has been stretched. A simple depression can be popped out. The 13 panel end caps were made of flat aluminum and do not have compound curves making fabrication simpler. You could also use auto body techinques such as bondo and then paint aluminum. From what i have heard the finish of an Airstream painted aluminum will last a lot longer than clearcoat and it is hard to tell the difference.
Old 04-03-2020, 05:40 PM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
My limited experience indicates not fixable in the sense that they will ever look like undamaged panels. Fixable in the sense that they might be pushed out enough to lessen the amount they show. Any pushing on Al stretches it and there is no way to shrink it back. It will take a lot of force to move those bent seams and usually applying that force will stretch the single thickness areas pretty badly when the thing you are pushing with deforms around the stiffer areas. If your goal is a polished perfect trailer I think you will need to replace the panels with the same original Al.
Old 04-03-2020, 09:04 PM   #6
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
I replaced 11 of 13 end panels on a 1957 Overlander. I removed each panel and flattened them the best I could. I used them as templates for the new panels I cut out of flat stock. It was a lot of work but very rewarding
My 57 Overlander thread ( Holly is her name)
https://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 04-04-2020, 10:51 AM   #7
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
Great find for sure! I would replace those 3 panels for sure. It's a great investment at this point.
Mikebrady62 is offline   Reply With Quote
Old 04-04-2020, 11:14 AM   #8
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera , Texas
Having been ďattackedĒ by a toll booth arm, my experience is that if the skin is creased, the panel likely needs to be replaced.
banderabob is offline   Reply With Quote
Old 04-04-2020, 11:24 AM   #9
2017 30' International
Lincolnwood , Illinois
Everything is fixable, The question is do you have the necessary resources ( AKA as $$$$)
Milo1952 is offline   Reply With Quote
Old 04-04-2020, 11:26 AM   #10
1998 25' Excella
Lynden , Ontario
I say get over the dents. I see worn character. Imagine, you won’t worry about more dents, one of the most stressful things about owning these vintage icons of design.
PatLawson is offline   Reply With Quote
Old 04-04-2020, 11:38 AM   #11
Mollysdad's Avatar
I'm sure you can get them much better. Roller from the inside. Or vacuum pump from the outside.
Then contact a "paintless dent repair" guy who has the tools and expertise to massage the metal back to almost perfect.
Old 04-04-2020, 12:33 PM   #12
1967 17' Caravel
Pocatello , Idaho
Pix please? especially the inside? Pretty please?
Old 04-04-2020, 03:25 PM   #13
Vivian
I was worried this might be a problem. I would want to polish it and want everything to match. Here are the other pics I found. It looks like there are 5 panels that would need to be replaced.
ID:	364833   Click image for larger version
ID:	364835   Click image for larger version
Old 04-04-2020, 03:44 PM   #14
The inside looks awful and would need to be gutted more than likely.
ID:	364837   Click image for larger version
Old 04-04-2020, 03:47 PM   #15
Ian
What is a fairly reasonable price? I think there are 5 panels that need to be replaced.
Old 04-04-2020, 04:57 PM   #16
Iansk's Avatar
1977 31' Sovereign
Ahh, the age old question...
Consider these factors:
- it will need to be gutted, no question.
- most likely needs a shell off, full monty
- frame likely needs extensive repair or out right replacement.
- new axles, tires, suspension
- new wiring, including inverter, breakers etc...
- holding tanks will need to repaired, replaced and/or added
- plumbing will need to be redone
- all penetrations will need to resealed (vents, windows, door, hatches etc...)
- and a lot more to get this into camping condition...
This brief list isn't to scare you off, but for you to really consider if you are ready and able to take the immense effort and investment this trailer will need.
I'm going to make the assumption that you would do the work yourself (you can) which will save you a lot of money but will be a time vacuum, which is fine if you enjoy it.
Now, to the question at hand... These are really valuable when restored really well and perhaps the owner knows this, but there is a Mariana Trench sized chasm between then and now. I would pay no more than 750-1000 based on what I see here and start even lower.
Can we ask what the asking price is?
Ian
Old 04-04-2020, 08:12 PM   #17
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
It is time for the English Wheel. If you don't like the results then use them as a pattern for new cutouts using the same stock as the original. Note: if the panels are anodized the creases will still be there as a white mark. Those sections are call "Pies" in the trade. There may be some available around the country, or as salvage, but good luck hunting.
guskmg
Old 04-04-2020, 10:59 PM   #18
I know there is a lot of work involved and I plan on doing most of it myself, except for plumbing and any welding that might need to be done to the frame. I used to work for an architect who has an Airstream restoration business and it's something I enjoy doing. The seller has this priced WAY too high and I don't know how much he would be willing to come down. He is asking $11k lol. I thought it might be worth $3k to $4k. I found a '54 Clipper from another seller that has new axles and brakes and new subfloor for $5800, which sounded reasonable to me, but I don't like it as much. I really like the alien eye models.
Old 04-05-2020, 08:53 AM   #19
Iansk's Avatar
1977 31' Sovereign
What something is ďworthĒ is relative as is evident in my $750-1000, your 3-4k and the sellers $11,000. I had a sneaking suspicion that because there was another Clipper in the photos the seller has an idea of what he has, however inflated that is.
Glad you know what your in for, too often folks get lofty dreams about these and end up making things worse. Plumbing isnít hard, itís just really annoying. If you can do most of the other stuff, you can do plumbing.
I feel like the seller is ridiculously overpriced, especially with the damage and what looks to be at least one missing window which I think is actually curved (I may be wrong though) and brings the value down even more.
Iíd make my best offer and happily walk away when they donít budge. Itís good that you know what you want, but this isnít the only one out there. I found several when sleuthing around for comps and saw a couple that were in far better condition for half this ones price.
Ian
Old 04-05-2020, 03:37 PM   #20
1967 17' Caravel
Pocatello , Idaho
I agree that $11k is wishful thinking on the part of the seller.
The pix of the interior don't look that bad, it's just dirty. You will of course have to replace the subfloor, so gut the interior, but take everything out carefully, don't break anything, and keep it all to see if cleaning things up might make sense to keep it as original as possible. And most old stuff is way better made than new stuff.
(Including us old folks LOL!! )
Vivian
Roof dents and front endcap dents martymcclain Roof 3 09-16-2017 01:54 AM
Are these dents fixable? simonla General Repair Forum 2 10-09-2015 04:47 PM
Can these dents be worked out on an English Wheel? gronlampa Ribs, Skins & Rivets 12 09-07-2015 01:50 PM
Opinion Needed on these dents mello mike Ribs, Skins & Rivets 8 07-17-2004 01:04 AM
Bad crunch.....fixable? Geff Ribs, Skins & Rivets 24 03-24-2003 11:27 PM
