Old 09-05-2020, 05:19 PM   #1
redthies's Avatar
1963 19' Globetrotter
1967 17' Caravel
1974 29' Ambassador
Top of the 395 , British Columbia
61 Bambi belly pan replacement
Can anyone direct me to a “good” source of inspiration/information for early ‘60s belly pan fabrication technique? I have the old pieces but they are completely trashed. I’m good with the process, but am having a difficult time with getting the triple compound curves in the front corners looking good. There has to be an easy way to do this? I received this trailer in boxes and pieces, so didn’t disassemble it myself so I’m kind of flying blind.
redthies is offline   Reply With Quote
Old 09-05-2020, 05:35 PM   #2
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
As a start you could try here; from post #56 https://www.airforums.com/forums/f36...ml#post1791636
Making a template from paper helps a lot with compound shapes.
truckasaurus is offline   Reply With Quote
Old 09-05-2020, 10:15 PM   #3
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
You might find some help in the blog from Frank's Trailer Works (Baltimore MD).
Go to the 2013 entries on a Caravel. I found his hints helpful when I first started.
http://frankstrailerworksblog.blogspot.com/2013/10/
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 09-06-2020, 01:19 AM   #4
redthies's Avatar
1967 17' Caravel
1974 29' Ambassador
Thanks guys. I think I was trying to do the impossible. My method is the same as what these guys are both doing, but I was trying to do one sheet across the whole front. My street side was great, but the aluminum just wonít flex enough to do both sides nicely . The factory pan was a front to back sheet through the middle, and added sheets on the outsides. I was trying to avoid more joints by going full width.
Iíll get there in the end... My last one went from an otter nest to pretty damn nice.
ID:	377817   Click image for larger version
ID:	377819   Click image for larger version
Old 09-06-2020, 02:39 PM   #5
Mrfixit
mrfixit51's Avatar
Bathurst , New Brunswick
Front belly pan to A frame
Originally Posted by redthies View Post
Can anyone direct me to a ďgoodĒ source of inspiration/information for early Ď60s belly pan fabrication technique? I have the old pieces but they are completely trashed. Iím good with the process, but am having a difficult time with getting the triple compound curves in the front corners looking good. There has to be an easy way to do this? I received this trailer in boxes and pieces, so didnít disassemble it myself so Iím kind of flying blind.
I had the same problem with my vintage restore. I have attached a few photos,how i went from the curve to the flat A frame. I could not help making an overlap which i sealed with silkaflex, and added a piece of trim to go up the curve against the A frame. I then used part of the same piece and bent it up to seal the body in the back of the a frame and tucked it under the front wall before putting the bumper on.
ID:	377860   Click image for larger version
ID:	377862   Click image for larger version
mrfixit51 is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
Belly Pan replacement Material for a 1963 Bambi Aktundra Belly Pans & Banana Wraps 2 06-11-2012 04:29 PM
Rear belly pan replacement Adam.Pyburn Belly Pans & Banana Wraps 8 10-03-2010 09:52 AM
Belly Pan Replacement Julison 1969-1971 Caravel 2 08-01-2008 06:46 AM
Belly pan corner replacement Dan Clayton Belly Pans & Banana Wraps 12 09-27-2005 09:01 PM
