Old 08-27-2021, 09:15 AM   #1
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Where to find channel cleats/clips?
I am rebuilding the bathroom of my '73 GT, using essentially the same design as the original. The original cabinet panels were held in place using a slightly more elaborate F-channel. The space where the plywood is inserted into the F has some steal "cleats" or clips that have little teeth in them to lock into the F channel, and to grab hold of the plywood. Most of the original ones were so rusty, that they are no longer useable. Does anyone know if these are available anywhere (and what they are actually called? I have tried the obvious places (VTS, ODM), but no luck. See the pics of the F channel, and clip.
ID:	402797   Click image for larger version
Old 08-27-2021, 10:54 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Fastenal? OODM - Out of Doors Mart in NC. are my best bets.
Old 08-27-2021, 11:34 AM   #3
Belegedhel's Avatar
Houston , Texas
Thanks--yes, I checked I check out of doors mart online parts, but I am tempted to give them a call as well. Tried several of the resource listings from vintageairstream.com, but so far, no dice.
If I knew what to call these things, it would be helpful. Actually, just talking about them is helpful, as I haven't checked my service manual for a part number/description--that will be my next stop.
Old 08-27-2021, 12:12 PM   #4
Belegedhel's Avatar
Houston , Texas
Ye olde service manual suggests that these may be called a "Tinnerman clip." A search online reveals that there is a vast variety of things with this name...
Old 08-27-2021, 12:50 PM   #5
1966 22' Safari
Fredericksburg , Texas
I’ve never seen those before. Are they used to wedge the 1/4” plywood bulkhead into the F channel and hold it in place? Looks like the Tinnerman U shaped pieces may work.
Bubba L is online now   Reply With Quote
Old 08-27-2021, 12:57 PM   #6
Belegedhel's Avatar
Houston , Texas
I'm not sure about the bulkheads, but likely so. I am working on the bathroom cabinetry, and yes, the 1/4" plywood goes into the F channel, and the clips lock it all together. There is a little groove in the F channel specifically for this clip to lock into. Most of what I find when I search for Tinnerman clips are those threaded nuts with a bit of a clip to attach it to a piece of sheet metal, or those push-nuts made of springy steel, so I figure "Tinnerman clip" is a vague expression used by AS at the time.
Old 08-27-2021, 02:58 PM   #7
Belegedhel's Avatar
Houston , Texas
Mission accomplished, and it only took me half the day! Outofdoorsmart came through for me with a very limited supply of exactly what I was looking for, but enough to get me moving. I hope I don't need a bunch more....
Anyway, if anybody else is looking for something that is approximately the same, search for "Tinnerman U clips."
These guys (below) are pretty similar, but you have to buy them in quantities of 2000!
https://www.fastenersuperstore.com/p...nuts?pid=17653
Old 08-28-2021, 12:33 PM   #8
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
That photo freaked me out! I thought you were holding a finger tip!!!
kidjedi is offline   Reply With Quote
Old 08-29-2021, 07:20 AM   #9
Belegedhel's Avatar
Houston , Texas
I see that now..reminds me of that trick every kid's uncle does where he pretends to pull off his thumb.
C channel/U channel replacement cole3444 Repairing/Replacing Floor &/or Frame 11 04-17-2019 05:20 PM
U channel or C Channel???? vintageracer Repairing/Replacing Floor &/or Frame 5 01-24-2016 06:49 AM
Trying to find Grandpa's Old Airstream...can I find it with Serial Number?? Jakescheid Our Community 13 11-22-2011 11:01 AM
Roof Vent spring clips 74SovereignInt. Roof Vents, Skylights & Fans 1 07-14-2003 08:43 AM
Need spring load clips for water heater door 68 GT. Jim Clark Water Heaters, Filters & Pumps 4 05-09-2002 07:39 AM
