Old 09-24-2018, 07:53 PM   #1
1973 23' Safari
1970 27' Overlander
Boerne , Texas
under bed cabinets - help
I am working on cabinets now in my 1973 safari with twin beds. Specifically, I am working on the cabinets/storage area under the twin beds. The bed platform will be hinged for easy access. But also trying to decide on drawers versus a door opening for access to bins in this storage area. I would appreciate any feedback on experiences with either. If you have pics and/plans, that would be great.
Greg1410 is offline   Reply With Quote
Old 09-24-2018, 08:41 PM   #2
drew05's Avatar
2011 25' FB Flying Cloud
Peculiar , Missouri
When I redid our beds from queen to twins, I had used a drop down door, and use plastic containers for storage. I would think that drawers would hinder the openness of the floor.
drew05 is offline   Reply With Quote
Old 09-24-2018, 08:47 PM   #3
DBSteed's Avatar
2008 27' Safari FB SE
Blairsville , Georgia
We just completed converting a queen to twin beds in our 2008 Safari and we chose the door opening for access to bins in the storage area. We have one door on each twin bed and we can get a several bins in each space. We like this arrangement so far. We also made the bottom of the nightstand a crate for our pups. It takes up some of the space under the head of the one twin.
You can see other pictures of our remodel at http://www.airforums.com/forums/f468...se-186848.html
Debbie and David
ID:	323646   Click image for larger version
ID:	323651   Click image for larger version
DBSteed is offline   Reply With Quote
Old 09-24-2018, 09:02 PM   #4
1969 18' Caravel
Greenville , whereEverIroam
Images: 20
I removed the doors entirely. They just get in the way and don’t really provide any benefit and add useless weight and make it hard to access what you want.
I found some great plastic crates that are nearly the same size as the door openings. I just slide these in and out. The bottom of the cabinet face keeps them well in place under the bed going down the road. They look great and work great and save weight!
skyguyscott is offline   Reply With Quote
Old 09-25-2018, 10:57 AM   #5
harryk's Avatar
2005 31' Classic
Venice , Florida
I built new twin beds for our 31 classic...Basically. there is a solid piece that shows towards the aisle. A long piece in the rear too that separates the equipment locker.
Then there are dividers that attach to those 2 long boards creating multiple storage lockers/bins...you can size them for your needs. My side has 3 bins & hers has 4. Then, when you want access, you unsnap a hold down strap and pistons lift the top with the mattress to give access to all the bins. They hold a lot !
etc.
harryk is offline   Reply With Quote
Old 09-25-2018, 01:32 PM   #6
meandher
2019 30' Classic
Miami , Florida
Debbie and David
how big are your pups , I have 2 of about 12 lbs , would they fit?
Docv is offline   Reply With Quote
Old 09-25-2018, 02:22 PM   #7
DBSteed's Avatar
Our 2 King Charles Cavaliers are around 20 lbs each. Your dogs would have plenty of room. The new crate actually continues under the head of one of the twin beds. Storage is still under the other twin. [ATTACH]323712
Old 10-01-2018, 07:24 PM   #8
1975 27' Overlander
Galena , Illinois
This is how we handled the storage under the beds. We only had the lift up the mattress option to get under neath. The mattresses are custom made I guess? but they are 15" thick and heavy. Too much for my wife to lift. I tried a compression piston lift, but it started to rip the hinge out of the wall and when it closed, the mattress could break your arm it came down so hard. I know it's not the lightest option but it makes the space once again usable
ID:	324233   Click image for larger version
75Bob is offline   Reply With Quote
2016 FC under sink cabinets Danecoyer Interior Restoration Forum 3 08-24-2019 07:37 AM
Reading Lights Under Front Cabinets in Bedroom 25FB KJRitchie 2006 - 2010 Classic (all lengths) 3 08-13-2019 05:17 PM
Lights under bed and under couch st3v0k3rr Lights - Interior & Exterior 1 04-27-2017 07:56 PM
Rear Queen Bed Platform/under bed storage AluminumGirl Cabinets, Counter Tops & Furnishings 0 04-18-2010 11:57 PM
What to do with carpet under cabinets? Nicksut Floor Finishes 8 06-05-2005 11:41 PM
