Old 07-14-2018, 11:57 AM   #1
ghaag's Avatar
2014 30' FB FC Bunk
2007 25' Safari FB SE
Jonesboro , Arkansas
Stainless Steel Counter Tops
Has anyone put stainless steel counter tops in their Airstream? If so, were you pleased with the looks and serviceability? Did you do it yourself or have someone install it. How did you handle the edges?
Thanks in advance,
Greg
ghaag is offline   Reply With Quote
Old 07-14-2018, 01:41 PM   #2
Totoro's Avatar
Huntington , West Virginia
Originally Posted by ghaag View Post
has anyone put stainless steel counter tops in their airstream? If so, were you pleased with the looks and serviceability? Did you do it yourself or have someone install it. How did you handle the edges?
Thanks in advance,
greg
ID:	316901Click image for larger version
ID:	316902Click image for larger version
Totoro is offline   Reply With Quote
Old 07-14-2018, 01:46 PM   #3
Totoro's Avatar
Ours are one piece. The corners are welded together, as well as the end piece and then ground/polished. We like it, but you cannot use it as a cutting board. I would recommend your local sheet metal fabricator.
Old 07-14-2018, 01:49 PM   #4
ghaag's Avatar
2014 30' FB FC Bunk
Thank you, they look great!
Old 07-14-2018, 02:01 PM   #5
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
A freind of mine is a sheet metal worker and helped me with this SS counter top in our Excella with soldered corner.
In our cabin he made beautiful zinc counters. The backsplash did not make it in before it burned to the ground in 2016
ID:	316904   Click image for larger version
Name:	DeLarge cabin kitchen close to finish.jpg
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 07-14-2018, 02:28 PM   #6
ghaag's Avatar
2014 30' FB FC Bunk
They look great, I am so sorry about your cabin!
Old 07-15-2018, 09:39 AM   #7
2019 25' International
Washington , Washington, D.C.
I had SS countertop installed in my kitchen in my last home. While I liked the look, it scratched easily and I was constantly polishing it to pick up the shine.
PatLee is offline   Reply With Quote
Old 07-16-2018, 08:16 AM   #8
ghaag's Avatar
2014 30' FB FC Bunk
Thank you for sharing, I certainly don't want to spend a lot of time polishing.
Old 07-16-2018, 08:28 AM   #9
kfrere's Avatar
2008 31' Classic
Lenoir City , Tennessee
Our counter top and kitchen sink are one big piece of SS, a pull out desk top is SS, and our shower is SS. Love all three. It has not been any more trouble to clean the SS than any other surface. Of course, I don't cut directly on the counter top because I've always used a wood block. The shower over time shows soap residue, but so does any other surface.
Kelly & Matt
WBCCI - #4335
2005 Diesel Excursion
2008 31' Custom Classic "Moonshine"
2016 Interstate "BugOut"
kfrere is offline   Reply With Quote
Old 07-16-2018, 09:09 AM   #10
1969 18' Caravel
Greenville , whereEverIroam
Images: 20
Since we were on a limited budget, we ordered and modified a SS restaurant table from Amazon, cutting out the holes for the sink, faucets and stove. We cut off the back edge and used a brake to form a 2" back splash. In this way, we were able to secure a 60" wide SS countertop for under $200, not counting your labor.
SS does indeed scratch. This is nearly unavoidable, and is part of the SS look over time. Go into any nice restaurant's kitchen and you will see the "patina" your countertop will eventually show. While you can buff and shine it out, it would be a near constant chore to keep it looking "new and unused"
SS is more durable and easier to keep sanitary than formica, and is much lighter than granite, marble, concrete or butcher block. It also goes well with the whole Airstream look.
skyguyscott is offline   Reply With Quote
Old 08-08-2018, 09:01 AM   #11
Atoka , Tennessee
Thanks for starting this thread. I'm wanting SS countertop too. Just talked to the fabricator and looking forward to that time in our remodel. I, as well, certainly appreciate the posts, comments and pictures!
DDFran is offline   Reply With Quote
Old 08-08-2018, 09:33 AM   #12
ghaag's Avatar
2014 30' FB FC Bunk
Thank you for sharing! How hard was it to fabricate the SS shower?
Old 08-08-2018, 09:34 AM   #13
ghaag's Avatar
2014 30' FB FC Bunk
Thank you for sharing.
Old 08-08-2018, 09:35 AM   #14
ghaag's Avatar
2014 30' FB FC Bunk
I would love to see pictures when you get them installed!
Old 08-08-2018, 09:50 AM   #15
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
I did the same
How do I delete attachments to make room for more?
BambiTex is offline   Reply With Quote
Old 08-08-2018, 10:15 AM   #16
1967 17' Caravel
I installed a stainless steel kitchen countertop (along with 3cm granite in bathroom and Gaucho side table) in my '67 Caravel. Sub-top was 3/4" BC plywood with a strip of 3/4" plywood laminated to the bottom of the sub-top around the perimeter overhang. The SS was glued to the sub top with the edges pre-bent and welded closed at the corner.
I originally toyed with the idea of a one piece (welded together) top and sink, but decided against it due to cost savings and easy of assembly/disassembly. Plus, that is the original '67 sink.
David F is offline   Reply With Quote
2015 counter tops and table tops Big Air Cabinets, Counter Tops & Furnishings 1 10-26-2015 02:46 PM
Corian Counter Tops Rod Pease Cabinets, Counter Tops & Furnishings 27 04-22-2015 04:01 PM
Counter top with stainless steel sink, faucet and cutting board Bob Riffle Airstream Classifieds 0 02-12-2015 08:29 AM
Steel looking laminate Counter Tops? surferstyler Cabinets, Counter Tops & Furnishings 18 09-05-2006 08:47 PM
Corian Counter tops smily Cabinets, Counter Tops & Furnishings 4 11-27-2002 07:31 AM
