Old 05-04-2019, 04:43 PM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Sofa Replacement Project - 2002 Classic 30
Thanks to blueloue69 for the suggestion and Ditter for some details I am now underway with my sofa replacement project.
Before Picture:
The sofa is out:
The sofa is gone (Thanks, Gerry and Roxanne):
The new one is ordered:
https://www.recpro.com/recpro-charle...-with-console/
Lots left to do:
1. Figure out where to put the 12V distribution panel and converter
2. Clean up the wiring mess, including relocating the slideout controller to get it out of the area for the new built-in end table/cabinet where the power panel will likely go.
3. Design and build the roadside end table/cabinet and the extension to the curbside chair storage/flip-up table base.
4. Wait for delivery - the color I wanted wasn't available from stock. Shipping in early June.
5. Install sofa
6. and finally, Go Camping and enjoy it!
I'll post some more pictures are progress is made.
Al
Old 09-10-2019, 06:27 PM   #2
Not much progress.....
Well, the loveseat arrived but life got in the way. First getting a new floor in the trailer, then a hip replacement surgery and PT rehab, and then a hurricane, but I'm getting close to starting the project.
Here's a picture of the loveseat:
It is temporarily in our great room until I can get the trailer to the house to rework the power wiring and install it.
I ended up with an extra so I have an unused one posted in the classifieds.
Al
Old 09-23-2019, 10:15 AM   #3
Finally some progress!
Life finally allowed me to make some progress. Good thing, we are supposed to leave 10/3 for a month on the road. While this post is about replacing the sofa with a recliner loveseat, you can also get a sample of our new floor. It is Mannington Adura Rigid vinyl plank.
Here's the before picture on the "wiring loom" behind the sofa:
To be fair, I added the two red/black pairs for ham radio and CB power and the white duplex cable to power the disc brake actuator. The wall wart is supplying 12VDC to the circuit with the AC so I can run it while working in the trailer. All other 12VDC is off. The rest is as I found it. Apparently Airstream re-uses designs for cabling to cut costs as the wire harnesses are clearly not designed for each trailer. There are numerous instances of excess cable just being stuffed out of the way.
Here's the converter and power distribution panel box with some wiring disconnected:
The power distribution panel, associated wiring and converter were in a box under the roadside end of the original sofa. I had to move it and rearrange the wiring to minimize the needed rework. I moved a ground buss bar to the back wall. I'm still deciding what to do with the power bussbar. I'm moving the distribution panel and converter to the roadside end of the new loveseat and will build a custom cabinet to sit on top of it for storage. I had to splice all the wires running to the distribution panel in order to move it. I cut them back in the middle so the original color would still be connected to the panel, not that it would do any good. My wiring bears no relationship to the diagram in my manual. There is a sticker on the door to the panel. It is different from both the manual and the actual wiring. At least it is a good depiction of the circuit breakers. I may re-connect everything so at least the circuit numbers would be right, or I may just figure out what all the circuits are and make a new label. Speaking of that, I figured out why there was a breaker in the floor of the box. Apparently one of the breakers failed and someone wired around it. I was upset until I figured out why. The breakers are all riveted to the plastic sub-panel and then the buss bars are mounted under the nuts on the breakers. To replace a breaker all the buss bars have to be removed (9 nuts and several wires) and then the rivets have to be drilled out. I guess I would have wired around it too, but I may take a shot at fixing it with a breaker mount which allows each individual breaker to be removed.
Test fit of the curbside seat of the recliner loveseat showing the cleaned up wiring loom:
Lots left to do, including making a piece of furniture.
Al
Old 09-27-2019, 06:52 PM   #4
More Progress!
I replaced the old Parallax 7355 one-stage converter with an Outback 60A unit. I cleaned up all the wiring and moved the power distribution panel over against the roadside wall. As a part of this move I put the long ground buss bar on the front wall, and relocated the umbilical junction box to the center of the front wall. I had to splice in about 8" of wire to most of the load lines. At the same time I re-organized the breaker panel to agree with the foil-cal on the door to the panel.
Here are pictures of the cleaned up wiring and the loveseat in place. I will be making a cabinet to sit on top of the power box to replace the storage lost from under the sofa.
ID:	353085 Click image for larger version
Al
Old 09-27-2019, 07:28 PM   #5
STREMN's Avatar
2008 30' Classic S/O
Hampton Beach , New Hampshire
Sofa Upgrade
Al and Missy,
Looking great...nice job! We'll miss you at Slider II.
Tom - S/OS #025
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
STREMN is offline   Reply With Quote
Old 10-08-2019, 06:47 PM   #6
Almost Done
Added a base behind the power panel to support a combination storage cabinet/end table. It is screwed to the power box at the rear and both are screwed to the floor all screws are in the same plank space so as not to restrict the movement of the floating floor.
Name:	Storage Cabinet Base.JPG
I built a cabinet to go on top. It goes back into the curve of the front wall. Missy stained and finished it, and lined it with foam and covered the complete interior with headliner material.
Name:	Storage Cabinet.JPG
The top is almost finished. After fitting it I will make the final placement of the recliner loveseat and mount it loosely to the floor, again to preserve the movement of the floating floor.
Al
Old 10-09-2019, 02:17 PM   #7
Finally Finished!
The cabinet/table top is on. I used cabinet door catches to hold it in place. I'm concerned they may not be strong enough to hold the top in place if the trailer bounces too much so I'm going to find stronger ones or add a z-bar at the rear and a magnetic kid-proof lock like I use on troublesome drawers at the front.
The recliners are bolted to the floor with 1/4" lag screws at the front just tight enough to keep them in place.
Here are a couple of pictures:
Name:	One Reclining.JPG
ID:	353889 Click image for larger version
Name:	Both Reclining.JPG
Al
Old 10-09-2019, 07:00 PM   #8
STREMN's Avatar
Really nice looking Al...you guys will enjoy that for many years! Kudos!!!
Tom - S/OS #025
Old 10-09-2019, 07:52 PM   #9
Thanks Tom. The recliners are soooooo much more comfortable than the original sofa.
Al
Old 10-09-2019, 11:18 PM   #10
1980 24' Caravelle
vallejo , California
what a great job, have a great time on your travels. kurt
ke6gkv is offline   Reply With Quote
Old 11-16-2019, 05:07 PM   #11
1999 30' Excella 1000
Gainesville , Georgia
We need to do this. Thanks for posting. Looks great!
svoboda2 is offline   Reply With Quote
Old 05-11-2020, 05:47 PM   #12
Ditter's Avatar
1994 30' Excella
Franklin , Ohio
Great Job thanks for the Tread it will help a lot of AS'ers.
Still working on mine decided to redo Jackknife material ordered today
Thanks Ditter
Ditter is offline   Reply With Quote
Old 05-21-2020, 06:24 AM   #13
Virginia Beach , Virginia
2016 28' FC sofa replacement
I recently replaced my uncomfortable sofa with a double recliner 58" in my 2016 flying cloud. The recliners from RecPro fit perfectly in the space and the install was not that difficult. I would recommend this upgrade and look forward to many years of relaxing comfort.
petermday is offline   Reply With Quote
Old 12-07-2021, 10:39 PM   #14
BAKERSFIELD , California
Hi Al & Missy
We have a 2008 Classic 30' S/O
Your Post have been very helpful.
Our plan is to also to install Recliners like you have done. Did you go with the 67" or 70" unit. Measurements are very tight. Are you able to use the pop up table at the entrance door. Has the recliner material held up as expected. I have heard of material problems.
Thank you
Attachment 353085 Attachment 353086
Al
Jim and Lori is offline   Reply With Quote
Old 06-22-2022, 01:04 PM   #15
Sorry I didn't see this when......
Thank you
I don't remember the length I ordered, but I used the small console.
I haven't solved the pop-up table problem yet. Someone posted they put it on a drawer slide. I haven't figured out the details.
The material on my recliners started cracking in early 2021. I contacted RecPro and even told them it might have been pet damage. They asked for a picture, replied "that doesn't look like pet damage" and replaced them under warranty. They asked if I needed the console and I said no. Well a year later, probably out of warranty, it started cracking. They replaced it. The new fabric feels different - we'll see how it holds up.
Sorry for missing your post. I thought I was automatically subscribed to any thread I started, but I didn't get a notification that you had updated it.
Old 10-15-2023, 02:51 PM   #16
2015 30' International
FREDERICK , Maryland
LOOKS GREAT! Were you able to keep this storage that was behind the original sofa? I can't tell from your photo. This is the exact same reclining loveseat we are looking at for our 2015 International 30'
Doc Foster is offline   Reply With Quote
30f Classic vs. 33f Classic Sofa davcarv 2016 - Current Classic (all lengths) 4 02-12-2018 11:10 AM
Sofa cover for jack knife sofa k9jackie Sprinter and B-van Forum 0 05-28-2015 05:30 PM
Sofa, side storage and bins - 2002 Safari DotTexas Airstream Classifieds 0 03-27-2015 02:44 PM
Sofa Reupholstery Project TinLoaf Upholstery, Blinds, Walls & Interior Finishes 87 07-27-2012 05:30 PM
