Old 01-31-2019, 03:25 PM   #1
Cispook's Avatar
2020 22' Bambi
Chillicothe , Arizona
Roof Media Cabinet
First time ever - we have a gap and screw that has given way or loosened on our FC 27FB. It appears I need to remove side panel in cabinet to address.
Anyone have experience to share or tips. Much appreciated
ID:	332713Click image for larger version
Cispook is offline   Reply With Quote
Old 02-04-2019, 09:43 PM   #2
Cispook's Avatar
2020 22' Bambi
Bump
Old 02-09-2019, 11:14 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
The side panel on Safari / Flying cloud was held in place.with 3 or 4 wire brads on my 2006. Just gently pry off using a putty knife or something similar. The panel is foam core so the brads should pull out of the front, and stay in the frame behind. When you are ready to reinstall, match the brads to the holes and thump in with your hand. Easy does it. Firm but no more, the panel is plastic.
PS - the plastic trim may have separated because it has shrunk a bit..
See if you can just push it back against the wall and hold it there with bits of double sided tape discreetly placed between the trim and the frame. The trim disguises a lot of flaws in cutting the panels. Erg! Quality Construction my foot.
Old 02-10-2019, 08:57 AM   #4
Cispook's Avatar
2020 22' Bambi
Thanks for the reply. Iíve found mine is all screw panel access. Remove everything from media locker to access. Waiting at our current local for a day of adventure to tackle same.
Itís not the molding as I can see the screw body and itís no longer flush.
Question is will it retighten or require larger size.
Opening nicely the media cabinet jgperrin 2018 - Current Globetrotter 1 12-24-2018 10:57 AM
Windows media help W/Firefox Devoman Off Topic Forum 14 12-20-2006 10:24 PM
Media Blasting Exterior fangthorpe Airstream Motorhome Forums 3 11-23-2003 05:47 PM
