Old 05-15-2018, 03:49 PM   #1
Fr Jeff
frjeff's Avatar
1989 29' Excella
Saginaw , Michigan
Reupholstering Couch
Decision made. Do not have the time nor energy to relocate batteries and converter and replace couch with recliners. Will be perfectly happy with the couch we have if we can make it more comfortable and more attractive (29 year old floral pattern).
So, wife has some experience in reupholstering and we are going that route.
I have read here of others being happy with their re-do, so need to just pick some brain power on the foams used.
If you have undertaken this project (or had it done), please share the specific foam(s) used - thickness, density, ILD rating, etc.
And, were you pleased with your foam or wish you had made a different choice?
My advance gratitude!!
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
frjeff is offline   Reply With Quote
Old 05-16-2018, 04:01 PM   #2
1987 32' Excella
Somerville , Alabama
Sofa
I reupholster our sofa using supplies from diy upholstery in Mississippi. I had ordered from before always been happy. I will try to attach photo.
The seat cushions
The seat cushions are two types of foam glued together. 2 inches density 2.4 med firm 40 pounds on top I glued 4 inches 2.4 density Med 33 pounds. They I wrap with Dacron wrap. You can get the cushions already wrapped but in this case I wanted a firm base.
The back cushions
Are 4 inches density 1.9 soft firmness. I wrapped each cushion with cotton batting because I wanted almost down feel so I did not use Dacron wrap.
I ordered all supplies from diy including foam adhesive,batting and wrap. The original had removable arms and I ordered bolster cushions and shaped them with electric knife. Density 2.4 med 33 pounds. I also used their hog rings. Hope this helps
Mden is offline   Reply With Quote
Old 05-16-2018, 04:05 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
In case he doesn't see this, PM SeeMore. He did his couch with new foam etc.
Al
Old 05-16-2018, 05:39 PM   #4
twobikes's Avatar
1997 25' Safari
Montgomery , Alabama
OR you might look st Costco got a faux leather sofa that fit right through the door and ( with a little hack saw surgery to the frame ) fit right over the batteries and converter. Bonus— one more storage bin fit under the new sofa. Cost was under $300 and installation took less than 2 hours...
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at https://airgo.blogspot.com
twobikes is offline   Reply With Quote
Old 05-16-2018, 06:01 PM   #5
1999 28' Excella
New Orleans , Louisiana
Will be following..we are getting ours recovered and foam added.
badkat is offline   Reply With Quote
Old 05-16-2018, 06:16 PM   #6
2000 30' Excella
Toledo , Ohio
We had ours reupholstered in our previous coach make sure you get new foam ours was a 1985 had it done about 5 years ago . we took it to a furniture shop and he did a great job .
woodfox45 is offline   Reply With Quote
Old 05-24-2018, 10:51 AM   #7
Fr Jeff
frjeff's Avatar
1989 29' Excella
Saginaw , Michigan
The seat cushions
The back cushions
Good info. Will likely be close to replicating yours. Thank you!
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
Old 07-14-2018, 10:57 AM   #8
2009 30' Classic
Huntingdon Valley , Pennsylvania
Hello woodfox45, We are looking at an '84 Excella and the sofa bed needs to be reupholstered. Wondering how much it cost you. Thanks.
Adirondack68 is offline   Reply With Quote
Old 07-16-2018, 06:28 AM   #9
1987 32' Excella
Cost
The cost was 400.00. Most of the cost was foam. I bought the chenille fabric when Hancocks was going out of business. Mood fabrics and DIY upholstery have good quality chenille at good prices. You can buy cheaper foam at Joanne fabrics but it is less dense and will not be comfortable long term. I had no labor costs. I would expect to pay 500-1000 for materials.
reupholstering cushions Lana Upholstery, Blinds, Walls & Interior Finishes 40 08-22-2020 06:32 AM
Reupholstering Gaucho Chillbilly Interior Restoration Forum 0 10-01-2013 02:53 PM
To couch or not to couch? Safari Tim Upholstery, Blinds, Walls & Interior Finishes 47 03-25-2009 02:51 PM
Will this couch fit my trailer?? JohnGalt48 General Interior Topics 4 08-07-2002 06:38 PM
front couch for 31 soverign center bath jim c taylor General Interior Topics 0 04-12-2002 03:58 PM
