RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 08-29-2018, 06:26 PM   #1
1971 27' Overlander
Kansas City , Kansas
Replacing Tambour doors with sliding doors
I've been meaning to post this for a while, as I have not found any info about replacing old Tambour doors with sliding doors anywhere online.
When I performed my restoration I really wanted to re use the upper cabinets, and after some trial and error, I replaced the tambour with 1/8th plywood on sliding track. I also replaced the horrible brown trim by cutting strips of 1/16th plastic panel that was left over from building my shower and sliding it into the groves. The new uppers function great and look great. I couldn't be happier with how they turned out. The original Aluminum frame and panel design is great, and it would be expensive to manufacture something that is as light and strong as the originals.
To install the track, I cut and glued strips of plywood into the bottom runner to bring the sliding track up to the same level as the frame. I then glued with construction adhesive, Knape and Vaught 1/8th plastic track into the upper and lower frames. To lock to doors in place I used magnetic latches. To make some fit, I had to make a simple bracket out of aluminum angle so the striker would hit properly. As I was not using all the cabinets, I also salvaged the aluminum up rights from the opposite side of the Tambour runners and replaced the runners with it. If you were only repairing the tambour, then you would either have to be happy with having the runners slightly visible or devise another way to cover them up.
ID:	321161   Click image for larger version
ID:	321163   Click image for larger version
Shermy1987 is offline   Reply With Quote
Old 08-29-2018, 07:02 PM   #2
1971 27' Overlander
In the bottom photo, you can see the bracket I made up for all the inner doors to allow the catch to function properly. You can also see how I replaced the Tambour runner by using the bracket from the opposite side of one of the Tambour runners off another cabinet,
Old 04-30-2019, 04:16 PM   #3
my3sonsdad's Avatar
Vienna , VIRGINIA
Thanks for posting! I am considering something similar. Though I don’t like he color of the anodized aluminum I think I can take care of that as well.
2001 Ford Excursion 7.3L
my3sonsdad is offline   Reply With Quote
Tambour Doors - Like New - Full set of aluminum finish doors with hardware from 2015 16' Airstream copenagle Airstream Classifieds 0 09-04-2017 04:08 PM
Tambour vs Custom Sliding Doors coairstream Upholstery, Blinds, Walls & Interior Finishes 16 06-27-2009 07:27 AM
Replacing credenza and lower tambour doors Lumatic Cabinets, Counter Tops & Furnishings 2 01-14-2007 12:04 PM
cost of replacing all tambour doors pearl Cabinets, Counter Tops & Furnishings 9 08-17-2004 06:11 PM
Replacing or repairing sliding doors Marc Marenco 1974 - 1979 Sovereign 2 07-13-2003 11:48 PM
