Old 05-09-2023, 06:14 PM   #1
Bluetick's Avatar
2018 27' Flying Cloud
bow , New Hampshire
replacing plywood frame cover for twin beds
The plywood frame covers on my Flying Cloud 27fb developed some mold. As I was scrubbing with vinegar and borax it dawned on me. Why not just replace them. Seems like I could use them as a template to cut new ones from some 3/8" plywood. Has anyone else done this?
Praat Afrikaans of hou jou bek.
Bluetick is offline   Reply With Quote
Old 05-09-2023, 08:29 PM   #2
2020 25' Flying Cloud
Chula Vista , California
I have, but only to match the twin mattress that was wider than the factory plywood base.
I bought a single sheet and cut it to fit.
I then used the left over scrap piece to add on to the second original twin plywood, screwing it to the wall side of the bed.
No mattress overhang now.
Oreg52 is offline   Reply With Quote
Old 05-10-2023, 12:44 AM   #3
2015 25' Flying Cloud
Schaumburg , Illinois
I had a similar concern about mold when I first got my trailer, a couple years ago. I did a couple things as part of my remedy to that concern.
1) used a cleaning solution with mold treatment/mold killer on the plywood surfaces
2) new plywood over the original plywood, also several inches wider to improve mattress support on the center aisle side. I used some large cardboard as a template for the curved sections, traced the template onto the plywood, then cut
3) put a ventilation “mesh” product (hypervent ?) between the mattress and the plywood to prevent any future problems, several commercial products are available for this
4) replaced the mattresses
So far, so good ….
1StreamDream is offline   Reply With Quote
Old 05-10-2023, 04:22 AM   #4
Bluetick's Avatar
bow , New Hampshire
So far, so good ….
Hmm. I'm wondering now if it might not be a good idea to finish getting rid of the mold, then using the mesh product. I've already replaced the mattresses.
Old 05-10-2023, 11:31 AM   #5
Napa , California
The additional support on the edges of the mattresses is worth of the cost of replacing the narrow plywood! More support means more comfort when either sitting or sleeping. We just took our original plywood off, recut new plywood with the additional width and put the new wider one down. We also used Hypervent to limit the moisture under the mattresses.
Atwebs is offline   Reply With Quote
Old 05-10-2023, 01:10 PM   #6
2008 25' Safari
Lowell , Arkansas
Faced with this, I went with 3/4 7 ply birch, and with the oversize mattress, it is wonderful! PO tried to do it with 3/8 3 ply, and it was awful, seemed like you were sliding off of the bed every time you rolled over.
J. L. Taylor is offline   Reply With Quote
Old 05-10-2023, 02:47 PM   #7
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
Great Idea!
The mattress overhang doesn't bother my wife but it bothers me. I am going to follow your lead on this.
Thanks!
Mikebrady62 is offline   Reply With Quote
marine plywood vs plywood vs osb bweldon Repairing/Replacing Floor &/or Frame 35 07-13-2015 06:29 AM
Replacing rear twin beds with memory foam mcair Upholstery, Blinds, Walls & Interior Finishes 12 06-10-2009 10:22 AM
replacing twin dinette beds project codybear Upholstery, Blinds, Walls & Interior Finishes 5 06-15-2007 06:04 PM
replacing twin beds 31airstream General Interior Topics 9 06-11-2007 07:14 PM
