02-11-2018, 08:00 AM
TetonStreamer
2021 27' Flying Cloud
Delaplane
, Virginia
Replacing Dining Table Top
I recently took delivery on a 2017 23FB and want to replace the Formica dining table top with solid wood top. Wanting to know if anyone knows of a Airstream knowledgeable vendor who is offering this type of custom replacement?
Teton Streamer - in The Toaster
Wilson, WY 83014
02-11-2018, 08:05 AM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
wood table tops
Plan on replacing the hardware to attach the mount. Now go to EBAY and search under Boat parts....Table top. You will get the best quality and a surprising variety. Mount your old hardware and the table.
02-11-2018, 08:17 AM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
I'm not aware of any "off the shelf" replacement wood tops for Airsteams or RVs that can be ordered from stock. It's a fairly uncommon modification and the variety of dimensions and wood choices would make keeping an inventory impractical.
We did replace the Formica top with a wood one, and simply had a local finish carpenter make the new table top and install it. Ours is a "piece of art" and cost more money than most people would want to spend but I'm sure a simpler design and less expensive choice of woods could be made to lower the cost. Also, you could consider a local cabinet maker or other woodworking specialist.
Bob Martel
WBCCI# 5766
02-11-2018, 08:41 AM
Tampa
I would think any good cabinet maker could make a top.
But there's a lot of options.
1. a plywood top with a routered emblem or name.
2. a solid top made from boards glued together, butcher block style. (Heavy)
3. a simple top because you want a bigger or smaller surface.
4. you hate formica.
02-11-2018, 09:37 AM
2015 27' FB International
2011 25' FB International
Lafayette
, Louisiana
See the Photo at the Link... http://www.ferdara.com/Client-Access...ry/i-g3g35pJ/AI had one custom made and used the original hardware. It is solid cypress from our area of South Louisiana. http://www.ferdara.com/Client-Access...ry/i-g3g35pJ/A
"Ferdara" Mark and Michael Broussard-Hubbard
Aluminum pulling Aluminum 2018 F-150 4X4 Platinum, 3.5L V-6, 10 speed trans, 6.5 bed, Max Tow 3.55 Elec Locking axle, Roadmaster Active Suspension ~ 2015 Airstream Custom Ordered 27fb International Serenity - Lafayette Louisiana
WBCCI 11100
02-11-2018, 09:57 AM
1979 30' Argosy
Everton
, Arkansas
My motorhome dining table was ruined by a leak and I'm going to replace it with solid oak. The table top is also the bed bottom between the seating so it has to be sturdy.
02-11-2018, 10:07 AM
2017 23' International
Washougal
, WA
That is beautiful. I think the table top that came as stock is less than desirable. I admire yours, and may copy it!
02-11-2018, 10:25 AM
Lafayette
, Louisiana
You bet... go for it!
WBCCI 11100
02-11-2018, 10:38 AM
1964 22' Safari
1968 26' Overlander
Beaver County
, Pennsylvania
Teton,
I'm not sure what you're looking for, from a style perspective, but we found a young craftsman (Adam Billstone) in Warren, PA that builds custom furniture of select hardwoods. He custom made our dinette table top(s), corner table tops and kitchen counter top all to match and each to our specific measurements. Ours have a rustic look to them. Her's a link to our thread that includes some photos and descriptions. https://www.airforums.com/forums/f39...er-155180.html Adam was as excited about the project as we were, so we dropped by his shop to show him how they looked.
Good luck,
Roy and Marie
02-11-2018, 10:52 AM
Dazed and Confused
Hillsburgh
, Ontario
Do any of you trailer people ever consider weight before changing things? A solid counter will weigh considerably more than a Formica table top.
I used 3/4 paper core Reboard, encased in a solid 1" white oak frame for screwing hardware too with solid core laminate on both sides. Very strong, durable and very light.
https://reboard.se
http://www.formica.com/en/uk/product...re#swatchesTab
These materials will never expand, contract or cup like a solid wood top will.
Cheers
Sidekick Tony
02-11-2018, 11:01 AM
1990 34' Limited
2013 27' FB International
Conroe
There are so many options to choose from. Get a local cabinet maker in your area, I’m certain they can fix you right up. Keep in mind to transfer the mounting hardware and be sure to inform them if it’s going to be used as a bed support once in awhile.
02-11-2018, 11:50 AM
2016 25' Flying Cloud
Sharps Chapel
, Tennessee
I want a smaller two-person tabletop for several reasons. Easier for conversation when another couple drops by. And easier to lounge behind when not eating (less confining).
But I want to keep my original tabletop for resale. So I would like to buy replacement hardware to fit in the same slots on the wall.
Source Airstream? Part Number?
02-11-2018, 12:39 PM
2016 27' Flying Cloud
Olympia
Found oak table on Craigslist for $25.
Cut off the last 1/3rd of it.
Mounted it on back wall of trailer.
Please see photo.
Richard Wills, Olympia, WA --- WBCCI 8873, WL7Z
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
RIP "BigDog": M Harlequin Great Dane, 150 lb
"St. Rocco": M Black Great Dane, 150 lb
02-11-2018, 01:49 PM
1964 26' Overlander
Warner Robins
, Georgia
A hardwood table isn’t difficult to make for a woodworker or cabinet maker. This is the one I build and installed in our 1964 Overlander during a full renovation/rebuild we recently completed. Weight was considered in my design. The finished table is 5/8” thick.
Caroyl & Tim
1964 Overlander "Gracie"
WBCCI # 31088
2009 F-150 "Big Red"
02-11-2018, 03:50 PM
Tampa
Before you saw down an oak tree, keep in mind that solid wood is heavy, and is subject to "checking", twisting and cracking with temp and humidity changes.
A table made of many small boards glued together is more stable than one made with a few. The assorted grain keeps the lumber from bending.
Furniture in $million dollar jets is made from corrugated "cardboard" with a thin wood veneer. Light and strong.
I think I'd shop Ikea furniture where their tables are made of hundreds of pieces of scrap wood. Not exotic, but stable.
Let an Asian woodworker do the hard part, you cut it to size.
02-12-2018, 04:03 PM
Antiquepedaler
2010 25' FB Flying Cloud
Laramie
, Wyoming
[QUOTE=CabinCruiser;2065451]I want a smaller two-person tabletop for several reasons. Easier for conversation when another couple drops by. And easier to lounge behind when not eating (less confining).
We replaced our 25 FB FC table top with an identical one, but 9” narrower, for a 19’ Bambi. It came with all hardware so the original is stored away.
Antique Pedaler
2021 Caravel 20 FB
02-13-2018, 05:43 AM
Sharps Chapel
, Tennessee
Originally Posted by Caroyl
A hardwood table isn’t difficult to make for a woodworker or cabinet maker. This is the one I build and installed in our 1964 Overlander during a full renovation/rebuild we recently completed. Weight was considered in my design. The finished table is 5/8” thick. Attachment 304012Attachment 304013Attachment 304017
I love your solution and how it folds down so easily. Do you use the same hardware as my 25’ FC? Can you post photos of the hardware and underside of your table?
02-13-2018, 12:19 PM
2017 19' International
Rosemere
, Quebec
https://reboard.se
Cheers
Sidekick Tony
I am new airstream owner and I don't understand these links, it leads to a page asking me to download things or continue to external link that is also asking to download, normal ? I am reserved about that,, got a virus like in my Mac with things to download last week. I sure would love pics of your table.
02-13-2018, 12:42 PM
2015 23' FB International
2007 19' International CCD
Steamboat Springs
I posted a picture on the 23FB Forum thread of a table top replacement. See post 421. There are other posts on this topic in the thread. May help with your research.
02-18-2018, 08:10 PM
1964 26' Overlander
Warner Robins
, Georgia
The first section is attached with a piano hinge to a narrow box/drawer like carrier with drawer slides inside that connect to a piece of 2x4 that is glued and pocket screwed to the bottom of a 7” wide solid walnut window sill. The sill is supported by the end of the banquette and a 1”x1” aluminum angle that is riveted to the skin. Small screws fasten the sill to the angle. Offset saw kerfs at each end allowed it to curve around the corners.
The second section is attached to the first using SOSS barrel hinges. The maple legs are hinges to the bottom of a drawer that supports the second leaf when pulled open.
Attachment 304228Attachment 304229Attachment 304230Attachment 304231Attachment 304232Attachment 304233
The first section is 25.5” by 26” and the flip out section is 23.5” by 26”
Caroyl & Tim
WBCCI # 31088
