Old 04-08-2018, 02:40 PM   #1
Franklin , North Carolina
Removing Storage Locker
Hello!
I have a 1962 26' Overlander and would like to remove the original storage locker. I'd like to simply remove it, and refinish the wall to be smooth. Has anyone removed one like this or have any advice in doing so? It looks to be built in, with no visible screws.
Thanks for any advice!
Bonnie
BForkner is offline   Reply With Quote
Old 04-08-2018, 03:27 PM   #2
1966 22' Safari
Fredericksburg , Texas
That headlocker is formed into the end cap. Its either thermoplastic or fiberglass with a gel coat. To remove it, I would think youd have to shallow cut around the perimeter then patch back. Otherwise youd have to remove the end cap and do the same with a little more room. Its going to be tough to patch back and make the patch disappear. Once cut, maybe stained 1/8 plywood or aluminum segments to cover the entire end cap, as many have done, so it all looks the same. My thoughts. Good luck. Bubba
Bubba L is online now   Reply With Quote
Old 04-08-2018, 04:34 PM   #3
Hi Bubba, ah I see. I think you're right - the 1/8" plywood would help cover the patch.
Thank you for your kind and helpful reply!
Bonnie
Removing the locker dividers on 2013 25 Intl. afk314 Electronics & Connectivity 8 03-20-2018 09:57 AM
Storage Locker on a 34 footer... lock LNorthway General Repair Forum 15 05-30-2017 01:25 PM
Unknown valves in storage locker mhilley Fresh Water Systems 4 04-21-2011 09:08 PM
Removing roof locker from bedroom worksology Cabinets, Counter Tops & Furnishings 11 02-21-2011 05:12 PM
I got jipped out of a storage locker! Becky B. 1984 - 1989 Sovereign 4 05-19-2010 08:40 AM
