Old 03-24-2020, 02:09 PM   #1
2016 23' Flying Cloud
Vancouver , Washington
removal of countertops in 2016 23' flying cloud
Hello! We are trying to remove the countertops in the kitchen area and the bathroom. There are some screws that we cannot figure out how to access to completely remove the counters.
In the kitchen, specifically, on the right-hand side where the refrigerator is. And
in the bathroom, there are two screws on the righthand side that we cannot see any way to remove them.
Any tips would be appreciated. Thanks! Ronnda & Thom
2stapletons is offline   Reply With Quote
Old 03-24-2020, 05:46 PM   #2
LilBigfoot's Avatar
2016 26' Flying Cloud
London , Ontario
Hi....I removed the counter tops in my 2016 26U. Not a job for the faint of heart. Removing the sinks first makes it a lot easier to reach all screws. Then I purchased the Dewalt right angle drill adapter to get into those tight spots. This made a big difference. Had my counter tops coated with an acrylic finish that really spruced up our AS. https://www.homedepot.com/p/DEWALT-R...RA50/203867866
You're a long time underground!
LilBigfoot is offline   Reply With Quote
Old 03-24-2020, 05:58 PM   #3
LilBigfoot's Avatar
London , Ontario
Old 03-28-2020, 10:46 AM   #4
Llittle54's Avatar
2016 16' Sport
Port Angeles , Washington
I removed the countertops on our 2016 FC. It first appears that you remove the screws that hold the countertop to the metal band that is attached to the sidewall. There are some screws just impossible to get to. I removed the metal band from the wall and left it attached to the countertops. I remade all the countertops reusing the molding between the wall and the countertop surfaces and used the original tops as a template.
Llittle54 is offline   Reply With Quote
Old 05-29-2020, 03:52 PM   #5
56ovalwindow's Avatar
2005 28' Safari S/O
Bountiful , UT
If you're still trying to remove the counter tops(to replace) and don't mind some dust, use a skillsaw and cut about three/four inches from the walls. Same for the front edge of the counter top. A small trim router can be used to connect the cuts and then use a hammer (gently) to bust the inner piece from the outer ring. This should give you easy access to the fasteners/screws. I'm getting ready to remove the kitchen C.T. and modify the end cabinet box in our trailer. Template the countertops if you're going to use the same shape.
56ovalwindow is offline   Reply With Quote
Old 09-23-2020, 01:27 PM   #6
2016 19' Flying Cloud
San Francisco , California
I have a 2016 19' CB Flying cloud. I'm interested in changing out my counter top as I just don't like the dark green marble look. Have any of you also replaced the vanity top, table and counter on top of fridge. i'd like to go lighter all the way around and I know my Airstream center will charge me a mortgage to do the work
Posse96 is offline   Reply With Quote
Bathroom Countertops Sanders Cabinets, Counter Tops & Furnishings 11 06-05-2007 07:38 AM
Aluminum Countertops! mcneon Cabinets, Counter Tops & Furnishings 12 10-13-2006 02:19 PM
Countertops...Again! Steve Heywood 1997 -2001 Excella 13 05-14-2005 01:34 PM
Corian Countertops??? Steve Heywood 1997 -2001 Excella 11 04-15-2005 08:12 AM
ABS Countertops Edie Cabinets, Counter Tops & Furnishings 1 03-23-2002 03:24 PM
