That would be a bit more challenging because it's likely not just the cabinet fronts. Even so, the process would be the same.
Do the necessary work to find out exactly what tint you want among wood stains. For me, that would include finding a piece of cabinet that I can take out and "sacrifice" as a model for the stains. Visit the hardware store and choose one or more that seem to be the best, under the conditions (hardware store lighting). Then try it out at home. See what you think.
Staining is the usual thing. Light sanding to remove any prior varnish. Vacuum and then use a tack cloth to clean it really well. Appy stain, not too heavily. Then apply varnish. I usually use a satin water-based polycrylic.
Lynn
Originally Posted by GreenTadpole
Thanks for continuing to help with ideas for refinishing cabinets in the Safaris. We are purchasing a 2008 Safari Sport and I'm not a fan of the golden colored cabinets. Has anyone tried staining them darker to look more like the color in the Internationals? Thanks for your help, Tadpole
