Old 06-29-2022, 04:24 PM   #1
2022 25' Flying Cloud
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
Push Button Latch Installation Help
I would like to install the Pantry Push Button Latch into the hall closet door. Is there a tool and/or tricks to the counter sink in the back of the door? I can just see myself going straight through the door with a big wood drill. I would prefer to not take the door off and wonder if any of you have installed this latch on a new door?
Name:	Push Button Latch 1.jpg
ID:	418603   Click image for larger version
Name:	Push Button Latch 2.jpg
Name:	Push Button Latch 3.jpg
2022 25RBT Flying Cloud, Dual AC, Full Awning Package, Solar and Convection Microwave.
2012FB is offline   Reply With Quote
Old 06-29-2022, 04:29 PM   #2
2004 22' International CCD
Beaumont , California
Not sure of the size of your latch, but there’s a special wood bit for cabinetry hinges; looks like might be the same.
Get the correct-size bit, then just feed the bit slowly with it turning normal speed and pull it out often to check depth by placing the latch in the bore. When it’s at the best depth, you’re done with that step.
There should be an illustration in the installation instructions to show you the bit type and size.
Ndcctrucks is offline   Reply With Quote
Old 06-29-2022, 04:33 PM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
The safe way to do this is with a Forstner bit in a drill press. The Forstner bit because it will give you a clean hole with a flat bottom, and a drill press so you have a way to drill at a 90-degree angle AND have a secure stop so you don't go through the door.
It would be possible to do this with a Forstner bit in a hand-held drill, but that's a move best left to someone who's done it countless times (or who has an extra door on hand to do it again.)
Richard
11018
richard5933 is offline   Reply With Quote
Old 06-29-2022, 04:49 PM   #4
2015 30' FB FC Bunk
Golden , Colorado
Thank you, Richard. Interesting bit. McMaster Carr had one so it is on order. I will take the door off and put it on a drill press or maybe the Bridgeport if I have room.
Old 06-30-2022, 11:59 AM   #5
I just did three blind holes for hinges with the Forstner bit I got at Homey Deport 13 years ago, by hand, and haven’t done it in years. The material I was working with was 3/4” oak-veneered plywood for a closet door in our AS. I drilled a 3/32” pilot hole 1/4” deep.
But a drill press, if you can get it set up rather easily, would be better.
Push button for light near black water drain m4dball Lights - Interior & Exterior 5 07-23-2017 12:37 PM
Push button pantry latch gloran General Motorhome Topics 2 09-03-2015 09:00 PM
Push button deadbolt lock jendon Doors & Locks 0 03-09-2010 05:14 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
