Old 06-23-2024, 10:49 AM   #1
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Plastic nosing in bathroom of '86 Sovereign
The creme colored plastic nosing on the edge of the bathroom sliding door and the two sides of the shower enclosure entrance are starting to deteriorate. The width of the center area is a half inch and the entire width which includes the part that slides under the aluminum strip is 11/16 inch. I have seen black vinyl for exterior nosing but not sure if it is thin enough. Does anyone know where I can get a replacement with a length of 74 inches times three?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 06-23-2024, 11:05 AM   #2
davidz71's Avatar
1986 25' Sovereign
Nosing on door
Here is another picture of the plastic nosing. One correction to my previous post, nosing in on both edges of the door and the other location is on the right hand side of shower entrance.
Old 07-20-2024, 11:37 AM   #3
davidz71's Avatar
1986 25' Sovereign
Anyone have an idea?
Old 07-20-2024, 03:53 PM   #4
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
You should investigate molding trims like the link to this brown one for potential substitution. The original stuff is likely long gone from the market.
http://www.amazon.com/Brown-Cherry-I.../dp/B0788RNQK9
Cowles (cowlesproducts.com) makes a broad variety among many other manufacturers. There many colors and styles.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
sovereign
Stainless stair nosing? pago cruiser Floor Finishes 3 03-27-2016 07:49 AM
Plastic bathroom components crack repair with 3M 4240 semi-rigid plastic repair kit Lance M Upholstery, Blinds, Walls & Interior Finishes 1 05-09-2011 07:11 PM
Plastic Bathroom Counters/Sinks lovingtahoe Cabinets, Counter Tops & Furnishings 10 05-06-2008 11:33 AM
Bathroom Plastic is cracked PhilMateo Sinks, Showers & Toilets 2 12-30-2005 04:30 AM
Painting plastic walls and bathroom sink jwaldin Upholstery, Blinds, Walls & Interior Finishes 4 11-14-2003 08:37 AM
