Old 07-08-2019, 05:54 PM   #1
2005 22' International CCD
Buckhorn , Ontario
Need help/solution for stripped cabinet mounting screw..pls
Over on my other thread I was talking about my loose overhead cabinet, and poor quality cabinet craftsmanship found simply because my cabinet at one side is loose..
So I’m concentrating on the loose screw for this thread. Took me 1/2 hour to back it out with needle nose plyer.
My problem is two fold. The wood side hole has wore out and screw sunk in further. Click image for larger version
This is where the screw should sit in the hole. The other one was buried much deeper.
The wall skin side hole has elongated and widened so the screw no longer holds.
Without having to take off the whole cabinet, what is the best way to re- mount a new screw?
There is another mount hole not used 6 inches back (not forward which would have solved the issue) but if used the screw would end up going through the window frame so no can do.
I could go larger thickness, with a washer on the wood side to make up the 1/16th inch loss of wood, but fear it would strip out the hole on the skin pretty fast.
What about using a Gregg jig to make a new angled hole beside it? If I can clamp the jig in that spot? And land just before the blind mount. So no fear of hitting any wires.
If I can’t get a jig in there, how do you make an angle counter sink hole?
Any help would be greatly appreciated.
05ModPod is offline   Reply With Quote
Old 07-08-2019, 07:21 PM   #2
2018 27' Globetrotter
Mooresville , North Carolina
As you probably know, these are "pocket" screws and a Kregg jig is used for this type joinery. There are different jigs for different applications. I can't get a feel for what you are trying to do based on your pictures. Maybe if the pictures weren't so close up, we could get a better idea of what and where the problem is.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
GOUSC is offline   Reply With Quote
Old 07-08-2019, 07:28 PM   #3
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
You could fill with JB QuickWood and re-drill. It’s great stuff.
Alumacoot
“We are confronted with insurmountable opportunities.”
Dan and Liz is offline   Reply With Quote
Old 07-08-2019, 07:50 PM   #4
2019 30' International
Pennsylvania , Pennsylvania
I have experience in that I was in the furniture business for quite some time. I often repaired stripped screws using Elmers wood glue and toothpicks, or a properly cut and shaped piece of wood or dowel to fill the stripped hole.
Use only the fat center part of the toothpick, cut several to length to fit in to the hole, apply glue liberally and shove toothpicks in hole, run screw in till tight. She'll set up real nice and tight when the glue dries.
Or, shave/whittle a piece of wood from a 2x4 or some other piece of wood, possibly the right sized dowel rod would fit perfect, apply the glue, shove and/or hammer the dowel rod in to place.
Make sure to cut the dowel, or whatever you use, to the proper length, and make sure it fits tight in the hole. I've used a hammer and punch to tap the wood in to the hole, and the wood glue is essential.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 07-08-2019, 08:30 PM   #5
Buckhorn , Ontario
Hi all,
I understand what you are all saying about fixing the wood hole, but what about the aluminum wall skin hole that has been trashed, in which the screw goes into.
I blew up the picture even more so you can see the hole. If it were just the hole made a bit wider, I could have gone with a larger diameter screw - but it is longer as well - do you think it would hold without slipping up and down in the hole?
Or do you think I have to make a whole new hole both in the wood and the aluminum skin?
I have room between the existing hole and the roller blind bracket to the left.
The good thing is that you don't see this mess once the roller blind is up - thank goodness.
Old 07-09-2019, 05:58 AM   #6
1987 25' Sovereign
Would it be possible to put a patch over the old hole (riveted or epoxied), then re-drill and re-mount?
Alumacoot
Old 07-09-2019, 11:28 AM   #7
Nomad518's Avatar
2001 25' Safari
Ridgefield , Washington
Take a piece of aluminum foil and roll it into a wedge shaped plug bigger than the hole. Push it into the hole and pack it in as tightly as possible. This forms a new surface for the screw to grab. Put things back together screwing directly into the old hole that’s now filled with compacted aluminum foil. This has worked well for me with all the screws that have loosened over the years on my AS cabinet hardware. Once done, I’ve never had to redo any of the fixes.
Nomad518 is offline   Reply With Quote
Old 07-09-2019, 12:49 PM   #8
2017 23' Flying Cloud
2023 27' International
Mesquite , Nevada
Use a rivnut
For $20 to $25 you can purchase a rivnut tool and fasteners. A good hardware store will have this item. It works like a pop rivet tool, but the rivet is threaded in the center to accept a machine screw. As you tighten the screw the fastener will expand more and be very solid - like a drywall or concrete anchor.
Ken G is offline   Reply With Quote
Old 07-09-2019, 02:06 PM   #9
Buckhorn , Ontario
Thanks for the last two suggestions. I tried the aluminum but alas it just kept going into the wall void. The hole is not round it is a long oval. I’m sure if it was round I might have had better luck.
I found a post about rivnuts and said awesome...but I would have to remove the cabinet totally to get it it in. I don’t have a man partner to stand and hold it and did not want to redo all the wiring to the speakers and lights that run into the cabinet.
So..... I drilled a brand new hole between the existing hole and the shade blind bracket...still a bugger to do in the space but worked like a charm saved me a lot of headache in removing the whole cabinet.
Put in L brackets on the three supports, to raise the underside so that the piece the factory forgot to screw in could be finished off. Could not get it totally flush as the wood had settled after all these years not being screwed.
Even though it is only cosmetic it drove me nuts. No more annoying piece hanging out every time I look up when sitting on my couch.
On the list of many maintenance items is waxing and polishing my interior aluminum-ceiling not finished yet, arms tired last night ug.
Just have to clean up the sliders and put them back in..
Thanks for all your input and help!
Old 07-10-2019, 07:56 AM   #10
callmedave's Avatar
2013 28' Flying Cloud
Cohasset , Massachusetts
Images: 14
That's the best fix you could have made without removing the cabinet.The tight space to work in made an aggravating job even worse I'm sure.The angled Kregg screwing arrangement complicated things even more. Well done!
Wallace: 2013 GMC Sierra 2500 D-Max
Gromit: 2013 Flying Cloud 28
_______________________________
callmedave is offline   Reply With Quote
Old 07-10-2019, 01:00 PM   #11
Buckhorn , Ontario
Flooring fiasco!
OMG sometimes life just does not give you a break...okay they missed the delivery - good for an extra week, then delayed again. So now my free layer - floor that is will be on holiday.
So they said they would check with their contractors see who could do the job. Two teams said no and one said yes with a $510.00 charge. And not sure if they could do it in the next two weeks....
Are you kidding me
My response.."how about this....cancel the order! The grey floor paint looks awesome about now!
He said that they thought that was the best idea even though it was now cut and on its way in 1.5 weeks. He said because we have messed you around we have no problem giving you a full refund.
He said he thought by the photos I sent the painted floor looked pretty good.
So for now - I'm going back in - fill the screw heads and bought a 4L can and will give it another 2-3 coats for durability.
Get my interior back in and worry about the next major job of getting her welded up and brakes changed out. At least the flooring refund will now pay for the brakes LOL.
Maybe it is a good thing - I can check her out in the fall to make sure there are no unexpected leaks, and the floor repair is holding up fine.
With the extra coats - it may look even better. I might just stencil in grout lines and done with it. Find a few cool carpet runners that match my accent red and black interior and call it a day.
If I do sell it - then the next owner can choose their own flooring ROFL.
Just my vent for the day.
Off to find out where my dang fridge is at - been in service now for 2 weeks.
Front Window Guard on 2015 Sport - stripped screw? mattmmatt General Repair Forum 0 06-10-2019 07:39 PM
Hitch Head Adjustment Screw Stripped! trekerboy Hitches, Couplers & Balls 21 07-17-2016 05:14 AM
Zip Dee Issues: upper bracket - stripped screw & plastic strip damage JConsroe Awnings 7 05-06-2016 06:05 AM
Approaches for fixing stripped screw holes in closet bonginator General Interior Topics 10 06-30-2012 09:28 PM
Zip Dee Awning stripped screw holes..... JKnight Awnings 3 08-24-2010 04:16 AM
