Old 04-18-2025, 11:17 AM   #1
2014 23' Flying Cloud
Brentwood , TN
Microwave drawer not latching
2024 27' FC RT - running down a bumpy road, our microwave drawer became unlatched, and our microwave dropped to the floor. Now we want to improve the latching ability of the drawer. Any suggestions?
richmkessler is offline   Reply With Quote
Old 04-18-2025, 12:02 PM   #2
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Shim the frame catch.
Oh boy, not what you want to find when you open the door to your trailer!
This is a common problem when the gap between the push button latch and the frame mounted catch is too great. It might latch when stationary but bouncing up and down will cause it to disengage.
Assuming the push button latch is still working correctly, the metal catch (angled part mounted to the cabinet frame) can be shimmed down so the push button latch engages more.
A friend with a 27’ had the same issue and shimming the catch down did the trick for him.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 04-19-2025, 10:25 AM   #3
Brentwood , TN
I'll try it
I'll try it. Thanks.
Old 05-15-2025, 11:30 AM   #4
2022 30' Globetrotter
Mentor , Ohio
I found the metal catch was loose on our 2022 GT, now I catch often. The latch underneath the drawer can be upgraded from a 5 lb to a 10 lb pull force latch.
Shinybus is offline   Reply With Quote
Old 05-15-2025, 12:34 PM   #5
Mollysdad's Avatar
Mine has a push button and I believe it's adjustable. Mine doesn't spring open. However, I was concerned so I measured the distance from the drawer to the opposite wall and it was about 26". I cut a dowel and added a white rubber crutch tip at each end. I just slid it into position before leaving and removed it upon arrival. Yours may vary. Also handy for propping the fridge door open when I'm gone.
Door latching issue Goondog Windows, Doors, Locks & Vents 1 04-07-2021 06:42 PM
Screen door no longer latching TheHoff Doors & Locks 0 06-13-2020 12:43 PM
Highest Amp Draw Across Latching Relay? pteck Electrical - Systems, Generators, Batteries & Solar 6 10-29-2017 12:39 AM
Latching relay power disconnect... romakdaddy Airstream Motorhome Forums 0 09-27-2017 04:06 PM
Question about wiring new battery charger on the battery side of the latching relay. BTUs4You General Repair Forum 3 07-27-2012 12:36 PM
