Old 06-28-2023, 09:29 PM   #1
2016 30' Flying Cloud
Phoenix , Arizona
Kitchen drawer slides out and falls
I cannot understand the mechanism used to keep this drawer from coming out. I see an orange tab on both sides of the slide that I think should stop the drawer but they don't.
Help.
Geno48 is offline   Reply With Quote
Old 06-28-2023, 09:41 PM   #2
2022 27' Globetrotter
Huntington Beach , California
Those are the “releases” for the drawer that allow you to remove it. This is not your problem. It sounds like you might want to consider changing the “latches” that hold the drawer(s) closed. I think that the OEM latches are 5 pound latches and others have replaced with 10# latch hardware
Slvr_Lining is offline   Reply With Quote
Old 06-28-2023, 10:18 PM   #3
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Geno48, Slvr_Lining is correct. The orange handles are the releases on the Blum drawer slides. The black plastic closer latch tension is not adjustable so replacing with stronger ones (find them on Amazon) is one option.
I decided to go with double-ball brass latches that are adjustable. You turn the screw to increase the tension (or go with a larger one). I went with 70mm ones for the large drawers under our sink and smaller ones for the silverware drawer.
The ones from Lee Valley are well made.
2019 27í Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 06-29-2023, 03:37 AM   #4
wilsodf's Avatar
2014 27' Flying Cloud
2023 30' International
Las Cruces , New Mexico
Does the drawer come off the tracks when you pull it out all the way. If so, replace the orange Grey pieces at the back of the drawer. They hold the drawer on the tracks. We have a new airstream and our drawer in between the twin beds opened and came off the tracks on our last trip. After replacing the orange/Grey catches at the back of the drawer, it may open, but not come off the track.
I may look into the 10 lbs latches, since this drawer, if you have to slam the brakes on will come open.
wilsodf is offline   Reply With Quote
Old 06-29-2023, 11:07 AM   #5
Ellicott City , Maryland
I had the same issue. Good solutions noted here - I installed a second catch, which solved the problem. I did the same with the bathroom cabinet mirror that would pop open every trip. One thing to look for on the kitchen drawer - mine actually damaged the drawer slide support bracing inside the cabinet from opening while in transit. So I also had to repair and beef that up in addition to adding a second catch.
Hughmclaurin is offline   Reply With Quote
Old 06-29-2023, 06:19 PM   #6
Sykesville , Maryland
And then there is the temporary/lazy solution. I just put some blue painters tape on each side of the drawer while traveling. I used to use duct tape but it left a minuscule amount of gunk behind. The painters tape does the job and leaves nothing behind.
mgblake13 is offline   Reply With Quote
Old 07-08-2023, 11:27 AM   #7
Phoenix , Arizona
kitchen drawer slides out
thanks for the different suggestions. It was the orange colored catch under the drawer. Our local Airstream dealer sold me a pair for $5. There are two screws that hold each one on so even I novice like myself can make this repair.
Very happy wife now that the silverware drawer doesn't fall on her foot.
Thanks again,
Old 06-14-2024, 12:31 PM   #8
2016 16' Sport
Miami , Florida
Thanks again,
Were the orange tabs not lining up or was there just not enough tension to keep the draw from going off the rail? Iím having the same issue. The orange tabs fit into the slots but a small tug will dislodge them.
Shiny16 is offline   Reply With Quote
Old 06-15-2024, 07:59 AM   #9
jeffmc306's Avatar
McHenry , Illinois
Shiny16, I found the plastic tabs on ours lost their sharp edge to stay locked in. Once that happens they donít have the strength to hold the drawer to the slide.
I bought a bunch of spares and carry some with us because the large galley drawers kept ending up on the floor even after I added the brass double-ball latches.
I fixed it for good by installing push button latches like the ones Airstream uses on the Interstate motor coaches. Wish Airstream used them on the trailer line as well!
ID:	444363   Click image for larger version
2018 FC23FB
WBCCI# 10258
RETIRED!
Old 06-15-2024, 08:50 AM   #10
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
i replaced most of the cheap plastic latches with the double-ball brass latches
they work very well
they come a various sizes from very small to large
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
waninae39 is offline   Reply With Quote
Old 06-15-2024, 06:44 PM   #11
2023 27' Globetrotter
Williamsburg , Virginia
Thanks again,
Our silverware drawer catches came loose because the screws were too small...all four were stripped. I replaced them with larger screws that bit into the wood much better. You might consider that when you install your latches.
AgBullet is offline   Reply With Quote
Old 06-15-2024, 07:27 PM   #12
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
For less work, I have added some sticky back velcro on the face frame of the cabinet and the drawer face. This along with taping the drawer closed with gaffer tape has worked just fine for us at this point.
Also did this on the curved under sink cabinet in the kitchen. Again, it works pretty well and was easy and simple
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 06-16-2024, 03:01 PM   #13
2016 16' Sport
Miami , Florida
My one kitchen draw keeps opening. Anyone know how many pounds “pull” the catch is? I see 10 pound ones on Amazon. I’m not sure if that’s an upgrade. Would just adding a second one help?
Old 06-17-2024, 07:39 AM   #14
2016 16' Sport
Miami , Florida
Thanks Jeff. I think thatís what is happening with mine. Where do u find the push buttons?
Old 06-18-2024, 11:25 AM   #15
jeffmc306's Avatar
McHenry , Illinois
Yep, I tried the stronger plastic latches, brass double-ball latches but when you get them tightened up all the way you have to put your foot on the cabinet to pull it open; not very convenient.
Foobar on the forum found these push button latches and had them installed. I got mine from Defender, a marine supply house. Itís all here in this post.
Scroll down to #18 to see my installation. It wasnít hard, just had to figure out where to drill the hole. I made a duplicate drawer front out of scrap plywood to use as a Guinea Pig / template.
Hope that helps Shiny!
2018 FC23FB
WBCCI# 10258
RETIRED!
Old 06-19-2024, 05:40 PM   #16
2016 16' Sport
Miami , Florida
Thanks Jeff!
Old 06-19-2024, 06:46 PM   #17
2021 23' Flying Cloud
2024 25' Globetrotter
Louisville , 40222
Cabinet latches
We had the kitchen drawer open and damage the slides on our first trip with our new globetrotter. Added this to my JC list and they installed extra heavy additional latches. They also added a short strap with a snap to the bathroom mirror to keep it from opening in transit. Tech suggested that instead of an additional latch. Just returned from 3500 mile trip both worked great.
Deholden is offline   Reply With Quote
Drawer slides backs breaking Torpedo Family General Repair Forum 0 05-14-2013 07:11 PM
Drawer slides crispyboy Cabinets, Counter Tops & Furnishings 8 02-20-2013 08:11 PM
drawer slides pol Land Yacht/Legacy Motorhomes 7 10-01-2012 11:30 PM
Drawer falls out in travel - any advice? Air_Dreamin General Repair Forum 5 04-23-2009 02:42 AM
Drawer slides 1988 345 howardann Airstream Motorhome Forums 10 03-15-2003 09:14 AM
