08-24-2006, 11:29 AM
1969 31' Sovereign
Los Angeles
Is this an original couch(es) layout??
Looking to buy this airstream, our first!, but want to know if this is an original config for a 69 sovereign - two couches up front in "L" shape....? One is a slider bed, the other not a slider?
Needs work of course, but don't want to start with someone's "custom" job, only want if it is an original layout.....will restore fully someday.....just haven't seen this config before....
Thanks!!!
- jc
08-24-2006, 01:02 PM
1948 16' Wee Wind
1953 21' Flying Cloud
Denver
1969 31' Sovereign floor plans
Hi JC:
If the 1969 Sovereign is a twin bed model, then the two front "L" shaped sofas are original, as seen in the floor plans below. If it is a double bed model, which had less sleeping and more storage space, then the "L" sofas are not original and someone has removed the front street side credenza and replaced it with a gaucho (pull-out sofa). Hope this helps.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life "From the Archives"
08-24-2006, 01:31 PM
2020 30' Flying Cloud
1995 25' Excella
Clear Lake
Love our '72 "L"
Mark
72 Sovereign: L couch, mid-twin, rear-bath "When you come to a fork in the road, take it" "It was impossible to get a conversation going; everybody was talking too much." "If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
08-24-2006, 02:10 PM
Round on both ends
1979 31' Excella 500
1975 28' Argosy 28
Rutledge
Boy, nothing like neatening things up for the buyer.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
08-24-2006, 02:24 PM
1966 26' Overlander
Woodstock
The 'L' is a desirable model, you will find that it can be very accomodating. Good luck with your purchase. Make sure you check other threads here to see what to be aware of when buying. Buyers remorse is possible if you don't know what you are getting into.
08-24-2006, 02:25 PM
1969 31' Sovereign
Los Angeles
Interesting......
I wonder if they moved the gouchu from under the front window to the side, then built the little couch and installed the table holder next to the door....
Unfortunately the current owner doesn't know any of the history....maybe I would use the chance to build a custom dinette or something unique...
Side question - where is a good place on the forums to post photos and ask "Is this "worth" $6000"?
(The rest of it looks pretty good and stock)
Thanks!!
- jc
08-24-2006, 07:38 PM
1995 25' Excella
Clear Lake
I love the "L" cause I'm 6'2" and the "L" couch offers a longer bed. I believe, the "L" couch was an option on the international (best) package. I can't remember if any part of the VIN number tells you about the couch. You may want to search the forum for that.
Mark
08-24-2006, 09:58 PM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Thanks!!
- jc
Start a new thread "Is it worth $6000?", post your pictures (as many as you want/have) in the thread and you'll get a response. Location-wise, try the '69 Sovereign forum...
Another idea is to utilize the members "Volunteer Inspector" services.
Shari
08-25-2006, 03:10 PM
1995 25' Excella
Clear Lake
At $6000 this should be a trailer that is used regularly and has some things that don't work. At that price, the floor could have some areas of soft floor around the door or around the toilet, but not significant. The trailer should not have leaks.
Always remember that when buying a vintage trailer, you are buying one because you expect to work on the trailer and you understand that the same trailer new off of the lot would cost you $50,000 (for your sized trailer) more. That gives you a lot of spending room for repairs.
I agree with InsideOut's suggestions.
Mark
