Old 08-02-2021, 11:26 AM   #1
Nashville , Tennessee
How to adjust curved cabinet hinge above bed?
How do I adjust curved cabinet hinge above bed? It wouldn't bother me except the light does not go off!
Any help would be appreciated.
Best,
CJS
cjsigmund is offline   Reply With Quote
Old 08-02-2021, 12:05 PM   #2
mikeinca's Avatar
2020 25' Globetrotter
Santa Rosa , California
Best,
CJS
Are you certain it's the hinge that needs adjusting? Is the cabinet door not closing flush?
If it is closing flush, your problem probably isn't the hinge. There are switches on the cabinet frame and the top of the door that have to be aligned properly and in proper proximity to one another to cause the lights to turn off and on. On some trailers the contacts are adjustable by loosening screws and on others, like on my 2020 Globetrotter they appear to be glued in place.
Check to see if the switches are aligning properly before messing with the hinges. They may need to be relocated. You wouldn't be the first person to have with this problem with the switches as installed from the factory.
Name:	contact switches.jpg
Mike
2020 25' Globetrotter Twin | 2017 F250 4x4 6.7 max tow Platinum
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
mikeinca is offline   Reply With Quote
Old 08-02-2021, 12:25 PM   #3
I door is misaligned now. Shifted down maybe a 1/4" to 3'8" of an inch
Also, my rig is a 2019 27FB GT if that matters
Old 08-02-2021, 01:06 PM   #4
mikeinca's Avatar
I figured it was a GT since you mentioned the cabinet curved doors.
The hinges on my 2020 GT are made by Grass so I'm going to guess yours are too. I don't have any personal experience working with these hinges but if you google "Grass hinge adjustment" you'll see a number of videos and "how to's". Good luck.
Mike
Old 08-02-2021, 03:43 PM   #5
Hinge above front window GoToasterGo Windows & Screens 4 06-15-2017 06:10 AM
Replacement Hinge for Curved Cabinet Door Hans627 Cabinets, Counter Tops & Furnishings 1 05-29-2017 07:11 PM
Heavy mirror above medicine cabinet titleists Cabinets, Counter Tops & Furnishings 12 05-24-2013 10:26 AM
How do I remove the cabinet above the fridge? RV H-D Lady All Argosy Trailers 13 12-11-2010 04:29 AM
