Old 12-26-2019, 03:35 PM   #1
moparjohn's Avatar
1973 25' Tradewind
Bloomsbury , New Jersey
HELP, looking to buy new harvest gold Formica
So I have a 1973 tradewind with the yellow/ gold countertop. I like it. I am installing a new stove/oven and need to put in a new countertop as it is a different size cut out. I have searched and searched google and more but can not find the right color and just buy a 4x8 sheet of Formica or similar. Anyone have any helpful leads? MPJ
moparjohn is offline   Reply With Quote
Old 12-26-2019, 05:57 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
https://www.lowes.com/pd/Wilsonart-S...E&gclsrc=aw.ds
Old 12-27-2019, 03:50 AM   #3
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral , Florida
Harvest Gold
Any of the big box stores should have a complete set of sample chips. Not, the display on the wall, which is a more limited selection from their preferred vendor. Rather, they should have a chain ring of every option. Almost anything you choose is a special order with a lead time of one to eight weeks, depending on the factory inventory, production runs and the popularity. You sure are lucky that you don't have to go with burnt orange or avocado!
dieseleagle is offline   Reply With Quote
Old 12-28-2019, 06:06 AM   #4
moparjohn's Avatar
1973 25' Tradewind
thanks
I'm a little weird, I try and not shop at big boxes if possible, but if they have what I need i will check them out. Thank you! MPJ
Old 12-28-2019, 12:30 PM   #5
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
Unfortunately it's the easiest way to make it happen. I think it's just the best (easiest/most cost effective) way for the manufacturer to grant accesses to the consumer. Note that you can order free samples from the Lowe's/HD websites, but it's often incredibly difficult to get all the colors to show up in your search. The physical store should have a giant collection of "chips" for you to sort through though.
Also, there are some "specialty collections" (boomerang and other mid century specific) that are available but harder to find samples for.
I'm sure you already know, but Wilsonart and Formica are the two largest manufacturers (most choices).
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
kidjedi is offline   Reply With Quote
Old 12-28-2019, 12:50 PM   #6
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Looking at the Formica web site I see they list a color as Sol (yellow). It's not Harvest Gold, but maybe it will work.
As others have said, Formica and Wilsonart are the two big manufacturers but I know there must be some smaller suppliers too. We see lots of restored trailers at Tin Can Tourist rallies and they seem to find vintage laminate so it must be out there.
You may have to diverge some from your Harvest Gold desires and find another retro color or pattern.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 12-28-2019, 01:02 PM   #7
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
Any builders supply (lumber yard/hardware) should be able to order this for you. Another source might be a custom cabinet builder who can tell you where they buy their material.
https://www.wilsonart.com/harvest-gold-d57
Alan
Old 12-28-2019, 03:09 PM   #8
moparjohn's Avatar
1973 25' Tradewind
thanks
again thanks for the replies! MPJ
Old 12-27-2020, 02:52 PM   #9
1974 27' Overlander
Placerville , California
What did you finally do?
I have a similar issue but we damaged the Harvest Gold counter top and would like to use the same. What did you finally do? I do not see this color on Wilsonart site. Also how did you deal with the portion that goes up against the wall. The laminate is molded up the backsplash and you just cant bend it like that from what I have seen even when heating.
Thanks for any help
Ron
ronsgto is offline   Reply With Quote
Old 12-27-2020, 04:07 PM   #10
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by ronsgto View Post
\Also how did you deal with the portion that goes up against the wall. The laminate is molded up the backsplash and you just cant bend it like that from what I have seen even when heating.
A cabinet shop can help you with that - it's a thinner version called "post-forming laminate". It comes in all the same colors - I'm pretty certain that all the countertops in vintage Airstreams used the post-forming type laminate throughout. Cabinet shops have access to the machines/tools that work with this all the time.
Formica & Wilsonart are the largest (most common) suppliers of plastic laminates as mentioned earlier. They do change their colors periodically to keep up trends and usually only offer "current colors". But if you google vintage plastic laminate, you can sometimes find new old stock that someone offers for sale - usually at a premium, but it is sometimes available.
Good luck!
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 12-28-2020, 12:39 PM   #11
moparjohn's Avatar
1973 25' Tradewind
countertop
I have been stalled by other things, and have not purchased it yet. MPJ
Do you like lime green, orange, harvest gold? Moonshot General Interior Topics 20 07-06-2013 08:48 PM
Looking for Formica meredith Cabinets, Counter Tops & Furnishings 14 08-22-2012 05:40 PM
Looking for a discontinued Formica white/gold fleck jeffmenzies Cabinets, Counter Tops & Furnishings 12 09-19-2007 04:20 PM
