Old 10-31-2020, 11:27 PM   #1
Jackroderick's Avatar
2018 25' Flying Cloud
MISSOULA , Montana
FB25 Bench Seat and table replaced.
I replaced the 35 X 39-inch table with a 27 X 39 walnut top using the existing hardware and removed the bench seat that I found to be uncomfortable. The narrower table allowed more room for a Lazy Boy swivel, rocker, recliner.
ID:	382337   Click image for larger version
Jackroderick is offline   Reply With Quote
Old 11-01-2020, 06:42 AM   #2
2015 25' Flying Cloud
Redmond , Washington
Looks great! Thanks for sharing. What did you use to attach the recliner to the floor?
McStreamy_ is offline   Reply With Quote
Old 11-01-2020, 10:14 AM   #3
MISSOULA , Montana
Using the existing screws that were holding the bench seat to the sidewall I attached nylon wire bundle loops. I will use a bungee cord to hold the chair in place during travel.
Old 11-09-2020, 05:02 PM   #4
1999 19' Bambi
Fountain Hills , Arizona
very nice thanks for sharing. I just got a 1999 Bambi. Tearing out the old carpet, then on to new flooring. Have you replaced flooring with something like vinyl? would appreciate suggestions.
Rosemary
BluMun is offline   Reply With Quote
Old 11-09-2020, 05:35 PM   #5
2010 25' FB Flying Cloud
Davenport , Iowa
did you have to make a raiser for the chair to adjust for the height of the table ?
I have done the same as your. I had to make a 3" spacer to make chair higher, and still have to use a cushion.
mj
Airtandem is offline   Reply With Quote
Old 11-10-2020, 03:05 PM   #6
MISSOULA , Montana
mj
No, I didn't make a riser, but I do have a concern about that. After making the changes I put the trailer in storage without taking any trips to see how it's going to work out. If I raise the chair then the armrest will hit the table and prevent the chair from directly facing the table. The first chair I tried was a Euro recliner and it was definitely not high enough. I had a tape measure with me when I picked this chair and selected the one I liked with a high seat.
Bench Seat and Cushions 2018 25' FC RWTL Airstream Classifieds 0 06-28-2020 02:27 PM
So you want to put a microwave in a FB25? daleyocum Our Community 27 05-19-2019 12:50 PM
I have put a TV on the wall behind the bench seat and table I need to get the antenna Trident Land Yacht/Legacy Motorhomes 34 09-07-2015 08:47 AM
What Solar panels Best fit a 06 Safari FB25? RichHog Generators & Solar Power 5 03-26-2013 09:53 PM
