Old 07-17-2020, 01:24 PM   #1
1976 Argosy 26
Reidsville , North Carolina
Counter top replacements
Replacing 76 argosy counter top. Does anyone know of solid replacement or ideas of what to use? Such as like in new model airstreams or any type replacement?
76argosy is offline   Reply With Quote
Old 07-17-2020, 02:36 PM   #2
1955 22' Safari
Laredo , Texas
Options
I have used Formica and stainless steel.
Name:	formica kitchen counter.jpg
ID:	373144   Click image for larger version
55AS is offline   Reply With Quote
Old 07-17-2020, 04:04 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Also used formica. Check out my blog.
Old 07-17-2020, 08:39 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Corian...
wulfraat is offline   Reply With Quote
Old 07-17-2020, 08:44 PM   #5
rd tighe's Avatar
2007 25' International CCD FB
South , South Dakota
Images: 13
ID:	373171We installed a Corian top in our 25 footer, but I did it for a living. Have seen granite (heavy) we did some laminate tops for some Airstreamers in New Mexico when we were there. So my recommendation is 1. Buy our fuel to come visit ( we are always looking for a reason) 2. Find a local company and see if they can do it at the amount of money that you want to spend. Good luck. And please post photos
Richard (Dean) Tighe
W.B.C.C.I. 5617
2007 25' FB International CCD Solar
2019 Toyota Tundra
rd tighe is offline   Reply With Quote
Old 07-18-2020, 02:17 PM   #6
SandKSmith's Avatar
Phoenix , Arizona
How did the stainless steel hold up? Would you do it again?
Steve
SandKSmith is offline   Reply With Quote
Old 07-18-2020, 03:06 PM   #7
1976 31' Sovereign
Oswego , Illinois
Word of caution Corian will burn if hot pans set on, can not be used for cutting board will make deep cut marks, small scratches will sand out. I have used a lot of corian & related matl. I do not recommend them, there some man made matl. that look like granite such as silestone for one, there are others made, one draw back w/granite other hard surfaces like granite, drop a glass object it, glass will break. I have granite in house, installed when expensive, prices down now. Penny & I like it never will have laminates, or corian style again. As for cutting boards wood is safe and doesn't breed germs like plastics and other matl. Butcher block makes exc. counter top min. care.
Old 10-13-2020, 12:07 PM   #8
First time Argosy owner
Pharanak's Avatar
1973 Argosy 24
Plantersville , Texas
An idea Iím tossing around right now is to use 2-part epoxy. So much research to do!
Corian is appealing because itís lightest and cheapest of solid surfaces.
Butcher block is really appealing right now.
Paper stone??? Only available in limited colors....
Regardless, itís a DIY adventurerís playground!
Good luck with your tops!
Pharanak is offline   Reply With Quote
Old 01-09-2021, 10:42 AM   #9
Peter B's Avatar
1994 25' Excella
Calgary , Alberta
I used 3/4 bamboo sheet goods. Sanded did a two colour stain. Covered it in that countertop epoxy. Looks awesome and is lighter than solid surface material and easy to fix or repair. Doing the bathroom this winter we like it so much. Just make sure you spray a coat of lacquer on it top and bottom before you do epoxy. Eliminates bubbles.
Peter B is offline   Reply With Quote
Counter Top Gasket Material Tom Bray Cabinets, Counter Tops & Furnishings 9 04-25-2008 11:21 AM
Sink and counter top replacement slimitch Cabinets, Counter Tops & Furnishings 8 01-07-2008 05:24 PM
Removal of the kitchen counter top fossil Cabinets, Counter Tops & Furnishings 3 04-11-2006 10:29 AM
removing counter top dmadam Cabinets, Counter Tops & Furnishings 6 01-12-2006 03:55 PM
resurfacing bathtub and counter top davidlaxson Sinks, Showers & Toilets 14 09-23-2003 01:30 PM
