Old 03-10-2025, 01:02 PM   #1
MSDeneen's Avatar
thousand palms , California
Can Anyone Identify This Dinette Bench???
My unit was "customized" by previous owners in some hacked out DIY way. I removed all his work.
Two of these benches were used in the dinette he built. I looked through both the 2010 FC and 2011 FC Airstream Parts Books and did NOT find any bench that looks like this.
Anyone have these?
Cheers,
Mark
2011 Flying Cloud 23 Front Bed
2019 Yukon Denali 4WD w/Hensley Ultimate Arrow
Loc: Palm Desert, CA
MSDeneen is offline   Reply With Quote
Old 03-10-2025, 02:58 PM   #2
BradS's Avatar
2006 22' International CCD
Plymouth , Minnesota
Images: 14
Yes. I have those benches in my trailer. I have a 2006 22’ CCD
BradS is offline   Reply With Quote
Old 03-10-2025, 04:11 PM   #3
MSDeneen's Avatar
WOW! We have a bingo! Well, at least they are AS parts. Thanks for the response!
Cheers,
Mark
Old 03-10-2025, 05:01 PM   #4
RMNummi's Avatar
2014 23' International
2022 16' Basecamp
2017 23' International
Saint Petersburg , Florida
Alternatively these look like 23 international Serenity benches circa 2018
RMNummi
TT: 25FBT Globetrotter
TV: 2023 Tundra 1794 Hybrid.
RMNummi is offline   Reply With Quote
Old 03-11-2025, 09:12 AM   #5
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Keremeos , British Columbia
Images: 30
International Models
As noted, these dinettes have been used in International and International Serenity models since the early 2000s to the current model year in the International line. You will see this dinette style today in larger models (28-30'). Here's a photo of a 30RB.
Name:	international dinette.jpg
Lisa and Paul
2017 30' FC | 2002 Chinook Destiny | 2008 23' Int. CCD (written off: hail!)
bolerama is offline   Reply With Quote
Old 03-11-2025, 10:33 AM   #6
2012 23' FB International
Woodstock , Ontario
Anyone have these?
Cheers,
Mark
That is the dinette in a 2012 Airstream International
We have the Serenity finish. Changed the original 4 inch cushions for a 5 inch seat cushion.
JCWDCW is offline   Reply With Quote
Old 03-11-2025, 10:45 AM   #7
MSDeneen's Avatar
Well, what a nice bindle of new information for me! Thanks folks - especially for that picture.
If any of you have that kind of TABLE, I would love to know the W x L dimensions. I will try to duplicate that layout.
Also, if you do have that table, when it is folded down, does it sit on a lip coming off the bench? Does it make a bed?
Sorry, if those seem like stupid questions, but I want get as much of the detail as I can before I start sawing and laminating wood!
Cheers!
Mark and Paula
Old 03-11-2025, 10:47 AM   #8
MSDeneen's Avatar
My empty dinette space
Here is my empty dinette space after removing all the modifications.
Old 03-12-2025, 09:10 PM   #9
bolerama's Avatar
Images: 30
Your original dinette did not have a table that attaches to the wall, but the previous owner added those brackets, so you have option.
Originally, your 23FB had a center pedestal that dropped down to form the bed. You also had rounded cushions in the corners of the dinette. I am including photos of a 23FB Flying Cloud with the rounded cushions and a 23FB International with flat cushions. Both of those have a central pedestal table. To be honest, I've seen many people change that design, or express their dislike of it. Maybe that's why the previous owner changed it. Ultimate Airstreams has now started renovating this area for customers. If you aren't familiar with Ultimate Airstreams, look them up for inspiration.
Because the previous owner added wall brackets, you don't need the pedestal table. Do you have the part of the bracket that attaches to the table? I am including a picture of a 30RB International with the table down in "bed" mode. The size of the table is 26x42, but that is unlikely to fit your space. You'll have to adjust the size of the table to fit your space. I believe it just sits on the bench when lowered for bed mode, but I'm not sure.
Name:	23FB Flying Cloud.jpg
ID:	451465   Click image for larger version
Name:	23FB International.gif
Name:	30RB International.jpg
Lisa and Paul
Old 03-13-2025, 10:08 AM   #10
MSDeneen's Avatar
WOWZA! Thank you Wendy and Paul for that thorough research!
That is VERY helpful stuff.
Ok, when we bought the unit last month, it DID have a pedestal base. It was the collapsable pedestral from AS. However, it had a massive, heavy, butcher block table mounted that was 2" thick and weighed maybe 40 pounds. It was impossible for us to even lift that table into the full upright position. ANd weirdly, when we did get it up, it left about 4" of leg room between cushion and bottom of table! He had also build a heavy vertical wall to cover the wheel wells and added boards outward from the wall to form a seat on the wall side of the table. It was an absolute hack job and I removed it. He had totally covered up the AC outlet and TV outlet on that wall.
I have rebuilt a nice wheel-well cover emulating the AS one. I am just waiting for my laminate to arrive to finish it. Until now, I was assuming that we should make a wall mount table to bring it back to original. But, your comment about the wall hinges now creates a new question about the pedestal base - which I have in the garage.
1. I tried to lubricate the base segments to see if I could make it easy to raise. Not really easy. Reaching under and operating the two latches are a PITA. And, I will go measure, but I don't think it raises to anything near 30 inches. There was a 12 x 12 x 1/4" aluminum base piece on top of the pedestal that the top was attached to. It has glides on it, and when driving, the table top was sloshing back and forth willy nilly even with the so-called latch locked.
2. We have no use for a "bed" conversion of the dinette - so that is not important to us. We also have no use or desire for a "horseshoe" style dinette, which is what the previous owner attempted to build.
3. I have none of the wall table parts that go on the table, but I did find a place to buy them. So, no trouble there.
4. One more oddity is the benches. The two legs are both far to the outside edge of the bench with nothing supporting the inside half of the bench. While it might look like that inside edge should sit "on the wheel well cover," I really doubt if that is the intention as it would require a super strong attachment of the wheel cover to the wall and floor. My current plan is to attach a LEG to the inside half of the bench that will go to the floor, not the wheel cover.
SO, lots to review and consider now! Again, that you for the information and photos! Brilliant!
Cheers!
Mark
Old 03-16-2025, 12:11 PM   #11
bmc5311's Avatar
2019 30' International
2024 25' Trade Wind
Manvel , Texas
I came here it say this.
bmc5311 is offline   Reply With Quote
Old 05-11-2025, 08:13 PM   #12
Moreland , Georgia
Those wall table brackets are the same ones my Bigfoot trailer has in it. As first I was going to say it is a Cass Hudson system but they don't have it on the website, so I'm not sure.
Charles
'03 Ram 2500 CTD, 5.9L HO PacBrake six speed std cab long bed Leer top and 2008 BigfootRV 21RB trailer.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
CharlesinGA is offline   Reply With Quote
Can Anyone Identify this? dnssandbox Batteries, Univolts, Converters & Inverters 26 09-11-2010 11:48 AM
Can anyone identify what I have marvin 1954 - 1959 Overlander 42 12-31-2009 10:12 PM
can anyone identify this window? / '56 Flying Cloud Ben_KC Windows & Screens 3 07-24-2009 09:44 AM
Can anyone identify these? bullydogsmom General Interior Topics 7 04-06-2009 05:20 AM
Can Anyone Identify? rhoward Airstream Trailer Forums 12 12-11-2007 06:42 AM
