Old 05-02-2020, 03:00 PM   #1
Lafayette , Louisiana
Cabinet
2019 25 ft flying cloud bought in dec
Round door below sink hinges broke off on last trip. Any help on replacing , repair otherwise it’s 3 hours to Mississippi we’re we bought it.
Whitn37140 is offline   Reply With Quote
Old 05-02-2020, 03:06 PM   #2
2018 25' International
Slidell , Louisiana
I might could help. Give me some details or photos, describe what fell off where....
Old 05-02-2020, 05:15 PM   #3
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
Hi there,
Is the situation such that the screws have come out of the screw holes and now the holes are too big to just screw things back together?
If this is the case, that is fairly common and not difficult to fix.
You will need: wooden toothpicks or skewers, wood glue, some type of clippers like a wire cutter or strong toe nail clippers, a standard emery board (nail file) or sandpaper.
1-cut several toothpick to be about ½ inch long.
2-coat with glue
3-pack tightly in the hole
4-let dry
5-clip off the ends as close as possible to the surface
6-sand smooth with the nail file.
Now you can re-screw the hinge into this to re-attach the door.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 05-02-2020, 06:35 PM   #4
2016 30' Classic
Houston , Texas
Originally Posted by Piggy Bank View Post
Hi there,
2-coat with glue
4-let dry
Great idea!
dhroberts is offline   Reply With Quote
Old 05-02-2020, 06:41 PM   #5
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Hi there,
2-coat with glue
4-let dry
And use screws that are one size larger (not longer). This is also a good time to learn how to make the adjustments on the hinges to get them properly aligned, so that the doors close properly and securely.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 05-03-2020, 04:30 PM   #6
Originally Posted by bayoubiker View Post
i might could help. Give me some details or photos, describe what fell off where....
Old 05-04-2020, 03:06 PM   #7
Slidell , Louisiana
So the toothpick and wood glue works great for the screw holes as was suggested. I'm going to assume the hinge did not fall apart. is it possible the cabinet was not fully latched closed or was not aligned and came open when you were traveling?
Old 05-04-2020, 03:20 PM   #8
2021 30' Globetrotter
East Northport , New York
Hard to tell from the picture... Did the plastic anchors in the door come out with the screws? I got tired of dealing with them constantly coming loose so I removed the anchors and epoxied them back in. Rock solid now.
James
Old 05-05-2020, 06:39 AM   #9
Piggy Bank's Avatar
Glad to hear that worked.
We also use a wire tie on the two handles to keep the doors secure during travel.
https://www.homedepot.com/p/Nite-Ize...K-01/203210641
Piggy Bank
1985 sovereign cabinet dimensions or alternative cabinet ideas Cat-n-Saysay Airstream Motorhome Forums 7 08-21-2019 10:34 AM
1985 sovereign cabinet dimensions or alternative cabinet ideas Cat-n-Saysay 1984 - 1989 Sovereign 2 08-18-2019 05:52 PM
Under-Cabinet Light = Scorched Cabinet! MohawkDaddy General Interior Topics 7 09-24-2015 02:47 PM
