Old 02-01-2020, 03:55 PM   #1
RuffRider's Avatar
2017 28' Flying Cloud
anthem , Arizona
Cabinet
I have a 2017 flying cloud. I am going to paint the cabinets white. I bought Kilz primer and Behr cabinet paint. Has anyone painted a late model cabinet before? If so, did you prep before the primer? If you used different paint, did you have good results?
RuffRider is offline   Reply With Quote
Old 02-01-2020, 04:16 PM   #2
Lafitte's Avatar
2019 25' Flying Cloud
Bullard , Texas
paint
I would use a primer first , then mix Flotrol with paint for a no-brush strokes finish..........
I always keep a supply of stimulant handy in case I see a snake ......which I also keep handy
Lafitte is offline   Reply With Quote
Old 02-01-2020, 06:09 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I would absolutely not do that. Airstream use Wilson art laminate. You will never get a good bond and with the temperature fluctuations it will eventually fail and peel off. Itís not like paining wood cabinets in your home. And even painted cabinets at home have a limited lifespan before paint gets chipped and flakes off in small pieces.
If you really really want white cabinets there is a new classic 30/33 model with white cabinets.
Youíll be sorry you did and resale value on your trailer will plummet.
wulfraat is offline   Reply With Quote
Old 02-01-2020, 06:15 PM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Another option is to paint the face frame, if there is one, and then go to a door manufacturer, (there are companies that just make new doors to order), and give them the old doors to redo and rehinge.
Cheers
Sidekick Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 02-01-2020, 07:32 PM   #5
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Laminate Painting
You may regret your initial choice of products depending on the which cabinet paint you chose. But... before you begin painting you need to be quite finicky about the pre-painting cleanse that removes grease and other minute particulate materials from the laminate. Wash with TSP (trisodium phosphate) and wet sand before starting the primer coat.
The best combination - use a urethane-reinforced acrylic paint, such as INSL-X Cabinet Coat. While it is more expensive than ordinary acrylic-latex paints, the urethane-reinforced products have better hiding abilities and will stick better to problems surfaces. Cabinet Coat is designed to adhere to plastic, metal, and urethane surfaces without a primer, but laminate and melamine surfaces require sanding before painting and a primer.
The alternative approach is to apply a 100 percent acrylic, flash-bond primer, such as XIM (Rust-Oleum), Bullseye 1-2-3 (Zinnser), or Fresh Start (Benjamin Moore), followed by two coats of satin or semi-gloss enamel paint followed two coats of clear acrylic sealer. Personally, I'd recommend Dulux Trade Super Primer as the initial bonding primer.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 02-01-2020, 07:59 PM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Why do you want to paint?
Have you considered resale value?
Old 02-02-2020, 03:04 AM   #7
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Those kind people who are reminding you that the cabinets are Wilsonite not wood are right. I saw a 27 EB last week that had been sanded and painted and passed on it for that reason - though there were other problems too.
The paint job was less than 3 years old and more filthy than chipped. Trailers get dirty fast. Breathing, cooking and sleeping in a very confined space, plus road dust from travel all contribute. Get a bucket of clean water and damp wipe one cabinet door - the woodgrain laminate hides dirt well!
Foiled Again is online now   Reply With Quote
1985 sovereign cabinet dimensions or alternative cabinet ideas Cat-n-Saysay Airstream Motorhome Forums 7 08-21-2019 10:34 AM
1985 sovereign cabinet dimensions or alternative cabinet ideas Cat-n-Saysay 1984 - 1989 Sovereign 2 08-18-2019 05:52 PM
Push Button Cabinet Latch, Cabinet lid stays left and right mb2017 Airstream Classifieds 0 09-06-2018 01:57 PM
Under-Cabinet Light = Scorched Cabinet! MohawkDaddy General Interior Topics 7 09-24-2015 02:47 PM
