Old 04-18-2020, 09:14 AM   #1
doughpat's Avatar
2019 22' Sport
Bend , Oregon
Allen key blocked by privacy curtain rail
I am almost certain this is just a bad design, but thought I would ask to see if there something Iím missing. The translucent plastic panels in my 2019 sport FB are loose and actually fell out during a recent tow.
It looks like the Allen key head that holds the grub screw in is blocked by the rail for the privacy curtain to the front bedroom. How irritating! I guess I will need to either cut back part of the rail, or remove it,Take the Allen screw, and then put it back inClick image for larger version
ID:	366024Click image for larger version
doughpat is offline   Reply With Quote
Old 04-18-2020, 09:45 AM   #2
CC
1972 27' Overlander
Heinsburg , AB
It's not a very convenient is it? I believe if that were mine I would consider trimming the corner of the rail for the privacy curtain.
CC
Camper Crazy is offline   Reply With Quote
Old 04-18-2020, 09:47 AM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
You might want to try loc-tite on the screws as they do tend to back out with the vibrations of road travel.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 04-18-2020, 10:48 AM   #4
They make an Allen tool called bondhus that should give you the flexibility to get that tight.
https://www.amazon.com/Bondhus-20199.../dp/B00012Y38W
Kanusport is offline   Reply With Quote
Old 04-19-2020, 09:18 AM   #5
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
doughpat......Your unit should still be under warrantee. I would do nothing on it and call your dealer or Airstream Corp to fix the problem.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Tim Allen's Dehumidifier FCStreamer Dehumidifiers & Ozone Generators 39 05-10-2020 11:18 PM
Propane tank leaking out of Allen screw on valve oldtrucksrul LP Gas, Piping, Tanks & Regulators 5 03-15-2017 07:41 PM
RV Park Near Allen, Texas Freedomrider On The Road... 10 10-05-2013 10:38 AM
RV repair in Dallas or Allen area? DTR General Repair Forum 8 03-27-2012 09:37 AM
Privacy curtain for front of 88 345 nemo834 Classic Motorhomes 4 08-05-2010 11:07 AM
